Question about Pride Health & Beauty
Wigwag fault code flashing on scooter..waht cause this problem and is it easily fixed?
  • Anonymous Mar 18, 2014
    the wigwag on the scooter has fell off how do you re connect it
  • 280 Answers
The throttle potentiometer error code is caused by a damaged or worn potentiometer. The fix for this problem is to replace the throttle potentiometer. The part is available from Pride based on the model and serial number. Hope this helps.
Posted on Mar 20, 2011
Testimonial: "Yes..we discovered this was the problem ..thank you!! "
  • Tony Minchew
    Tony Minchew May 04, 2016
    Did not fix the problem. 185.00!!
  • wcdoc1953
    wcdoc1953 May 07, 2016
    There is also a speed potentiometer wired in series with the throttle potentiometer. For a complete and thorough repair, it is advisable to replace both.
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Feb 08, 2016 | Pride Health & Beauty
Light is blinking a 7 fault code, what does this fault code mean.
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Oct 23, 2014 | Drive Medical Spitfire Travel 4-Wheel...
What problem if Code flash 7 times?
hi, normally that error is associated with a wigwag error, either not centrer or a more seroiuus problem ) the lever you move to go forward or backwards, can you please confirm what controller is fitted is fitted to this scooter ? this will mean you removing the seat and rear cover , please take when doing this ..
Regards
Rob
www.gewizrepairs.co.uk
Jun 13, 2014 | Drive Medical Odyssey LX 4 Wheel Full Size...
Why does my freerider westminster **** when wigwag is pulled?
Hi,firstly it could be a worn throttle pot , incorrect values being received by the controller..
Secondly , the brake could be sticking hence the delay then movement and that would affect you in both directions...
For the brake i suggest you spray some contact cleaner or WD40 but remember you're lubricating the brake so take care when testing as it may still move when you stop...
Regards
Rob
May 21, 2014 | Universal Health & Beauty
Sundancer scooter flashing wigwag code
The wig-wag can be tested with an ohm or multimeter. The wigwag plug must be disconnected in the tiller console or at the split-frame connector. Speed dial must be turned up all the way. Measure the wigwag with the ohm meter from the outer most tabs. It should read 5,000 ohms +/- 5%. Then measure center tab to either outer tab. When in "neutral" position it should read 2,500 ohms +/- 10%. If the wigwag is in tolerance I would have the batteries and battery harnesses checked next. Each battery should be charged and tested by a battery shop. These should be 12volt 18-35amp hour batteries.
If the batteries test fine then you have a wiring issue where a loose or corroded wire is dropping voltage under load. Sometimes these types of "bad" connections will cause the wire/connector to become warm or even discolor the connector/wire.
Best regards.
Mar 05, 2014 | Pride Sundancer 3 Wheel Electric Scooter
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Numbers flash from one through to four in order on sc233ala model mobility scooter and will not drive
Hi. Is a Fisher and Paykel scooter? While the lights are flashing, press the horn button. The lights will stop flashing and display a fixed pattern, this is the fault code. Once you have done this let me know what it is, and I will be able to tell you what the fault is.Neil.
May 20, 2010 | Health & Beauty
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Health & Beauty Logo
1,005 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
