I have to replace the belt in my 2002 Frigidaire washing machine. I need instructions. Thank you :-)
    Brigadier General:
  • 6,277 Answers
I am having to assume this is a front loader!
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Good luck,
John C
Posted on Mar 18, 2011
My Frigidaire Crown top loading washer (M#-CRWS5700ASO) makes a frightening squealing noise on spinning. How to tell if it's a bearing or a belt? If a bearing, tell me about replacing it. Than
Good Morning Steve Wilkes, thank you for your post!
Based off the information you have provided your Frigidaire washer is squealing and making a loud noise while it is spinning. I understand that you would like to know how to locate if the bearing is bad or the belt. Unfortunately there are no instructions to provide you to locate which part could be faulty. Since it could be either one of these issues I would recommend contacting a professional technician to have a diagnosis to be completed this will help to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Jan 30, 2015 | Frigidaire Washing Machines
How do you replace a belt on a Frigidaire Washer, ModelLFT2940ES?
Hello Friend, this is Z. Thank you for your inquiry!
I see that you would like to know how to replace the belt on your Frigidaire washer, LFT2940ES. In this regard, I suggest seeking professional advice when dealing with intricate part replacements such as this since it requires precision and patience. One must be very careful as they replacements can lead to other potential damage. Best regards!
Jul 11, 2014 | Frigidaire Washing Machines
Drive belt replacement aft7000
Good Afternoon Friend,
I understand you want to know how to replace the drive belt in your Frigidaire washer, model# ATF7000. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the drive belt with ease. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
The tub does not turn in the rinse/spin cycle but the motor is running.
Hello Jwwood,
Your Frigidaire GLTF2940F washer is not moving when it is washing clothes. This is because the belt is broke you can locate the belt on RepairClinic.com. Before you order the belt you need to findout the length as there are many different lengths and styles. In order to get to the belt you need to remove the back of the unit. If it is broke as I beleive measure and post back to this thread or go to the following link find the proper size and order. LInk - http://www.repairclinic.com/Frigidaire-Washing-Machine-Belt-Parts
Thank you for choosing FixYa.com
Mar 06, 2011 | Frigidaire GLTF2940F Front Load Washer
Washer will not spin
Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Will not spin,
Washing machines may drain but doesn't spin because of the following reasons:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Thank You
    Jan 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Belts slips off
    Belt is too loose and probably needs to be replaced.
    Jul 12, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    24 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
