Question about Mtd Garden
Starter acts weak needs help to turn engine over
  • mbdawgs Mar 18, 2011
    battery and starter are brand new it works ok sometimes
  • 11,800 Answers
You have a bad electrical connection - check all of them for proper fitting and clean the corrosion /oxides that have appeared on them. Also check the starter relay by jumping it - connect the starter directly to the battery when the fault appears: if the engine turn normally then you will know for sure that you need a new one.
Posted on Mar 18, 2011
  • 4,924 Answers
It means that the battery is weak ...if it is on a 12 V battery ..just connect it with some wires to your car's battery ...(connect the batteries in parallel ) ..start the car's engine ...and after that start the mower ...and remove the wires... Check out why the battery is dead...probably it is not charging well ...
  • Catalin Turcu
    Catalin Turcu Mar 18, 2011
    By the way ...if you do not have original current cables...use some real thick cables..and tide them well on the batteries ends ...cause this is a high amperage current ..and they need to be thick ..even if the voltage is low..
Starter wont turn flywheel
starter motor weak. weak battery or engine is seized. take the spark plugs out and turn engine over with spanner on the bottom bolt on the pulley. if thats fine and move the engine freely then check the battery try a jump off a good battery. if not good and still will not start with the spark plugs back in then the starter motor is weak and needs changing. can do any of these in any order you like.
Jan 02, 2014 | 1987 Ford Bronco II
When I turn the key to the start or run position the power goes out. If I turn it to aux. its just fine but I need to roll up windows. new battery new bat. terminals all cont. are tight is there a reset...
I have a similar problem with my van. What is happening, is that there is a weak connection, that sometimes (or almost always, in some cars having this sort of problem), not enough current gets through to the starter or other engine parts, so once the current draw is too high for the weak connection, everything acts like the battery is dead. It is very difficult to track down because testing for continuity acts as if all connections are good, because there is still a connection, it just cannot handle the needed current.
In my case, simply moving or bending part of the wiring harness close to the battery makes everything work fine for about the next two to four weeks, until it works loose again. In my case, I need to replace that part of the wiring harness. I just have not yet done this myself yet due to finances and available time.
I know it sounds strange and you wonder how power to the starter or engine could affect the other parts, but it does. Not even as much as the dome lights would come on, once any part of the engine takes enough power to cause the broken, frayed or weak wire inside of the loom to seperate.
On some vehichles, a possible work-around could be to first check to make sure all connections to the starter motor are good and tight, and if the problem still happens, then get a somewhat universal starter cable that connects between the battery and starter. The "propper" fix, however, is to replace the entire wiring harness if it can be afforded.
Sep 30, 2013 | Dryers
When I turn key on it looses all elect power
In my case, simply moving or bending part of the wiring harnes close to the battery makes everything work fine for about the next two to four weeks, until it works loose again. In my case, I need to replace that part of the wiring harness. I just have not yet done this myself yet due to finances and available time.
I know it sounds strange and you wonder how power to the starter or engine could affect the other parts, but it does. Not even as much as the dome lights would come on, once any part of the engine takes enough power to cause the broken, frayed or weak wire inside of the loom to break.
On some vehichles, a possible work-around could be to first check to make sure all connections to the starter motor are good and tight, and if the problem still happens, then get a somewhat universal starter cable that connects between the battery and starter. The "propper" fix, however, is to replace the entire wiring loom if it can be afforded.
Sep 28, 2013 | Dryers
Husqvarna Rider Mower
Could be 3 things valve lash is one. Second is weak battery. Third could be bad brushes in starter depending on how many hours on unit i would start with load teating battery then check the valve lash then go to starter
May 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My 19.5 hp briggs and stratton engine is geting fuel and spark and the starter seems to act right but it does bind at times i have rotated the engine by hand and it does get pretty hard to turn in
try and jump start it with your car to see if the battery is weak if still struggle to crank try and jump direct to the starter motor if struggles direct to the starter then the starter appears to be bad
Aug 14, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When i try to turn the key all you would hear is a click...radio and windows and lighs etc. were working but the truck would not start.Bought a new battery same thing happened just a click...also bought a...
Hi, you may have a bad battery cable, but first check the 30 amp fuse 101 under the hood. If that's good, check the cable from the battery to the starter carefully for weak spots, where it will bend easily. Also check the cable from the negative terminal for weak spots. It that cable goes to the frame or chassis rather than the engine, also check the ground strap from the frame to the engine.
Jun 18, 2011 | 2004 Ford Expedition
I have a 1986 Honda Shadow VT1100. The engine turns over slowly, has a weak spark and will not start. When I take out the spark plugs it turns over fine. The engine acts as if it is hitting against the...
Are yousure the battery is not weak? thats what this sounds like to me. What makes you think the engine is hitting the starter. The starter goes on the tranny.
May 09, 2011 | 1987 Honda VT 1100 C Shadow
2004 sportster, engine light comes on then goes off. 12,000 miles on bike. notable; when startimg it acts like it's not going to turn over but then always does, battery is 2 years old. could this just be a...
engine light may mean change or add oil or airfilter is dirty.make sure all hoses are still hooked up.The pause befor starting could be the battery but is more likely the start relay solenoid or the starter brushes are worn and may need cleaning or replacing.the brushes wear out and leave their dust in the starter causing the resistance in the starter to get higher over time.(slow to start spinning,and acts like battery is weak.)
May 06, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
Starter not working when engine gets hot
Starter is weak. replace the starter and see if that fixes your prob. Once the starter gets hot, its not making good connection inside the starter housing, making it turn over slowly
Jul 05, 2009 | Ford F-150 Cars & Trucks
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
59 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
