Question about Ovens
My oven needs a new timer model no Euro ef60ss, where do I purchase one from and i it seasy to replace yourself? Thank you
2 Suggested Answers
SOURCE: Cata Single Oven Stainless Steel EF60SS Can't get it to heat up
Hi Ya
I have the same oven with the same problem.
To resolve the problem you will need to replace thermal switch, which can be found at the rear of the cooker behind the protective cover. Approx at the bottom left corner. It looks like the shape of an eye with to wires. Hope this helps. Kevin Reseigh
Posted on Jan 18, 2010
How do I remove the clock/timer assembly that is integrated into the glass fascia panel of an Electrolux oven EOB63100K? The new part I have purchased is complete with its own small fascia panel
Open the oven door and remove the two screws. Pull out the oven and disconnect it from the power source.
To replace the timer you should to remove the two upper cabinets of housing of the oven.
Dado
Feb 18, 2015 | Electrolux Ovens
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Hi Ya
Jan 10, 2010 | Ovens
Whirlpool gas range model # GS475LEMS0; Oven light won't come on
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. 250
Nov 16, 2009 | Ovens
No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Apr 12, 2009 | Ovens
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Mar 05, 2009 | Fisher Ovens
Oven not heating to proper temp
go to: RepairClinic.com
you'll need make & model #.
Nov 16, 2008 | Frigidaire Ovens
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
