Question about Westinghouse SK-32H240S Television
We have an antenna. Can't get Ch 3 on this tv to use our vcr/cd.
  • 1,591 Answers
If you did a channel scan to build the channel list, the up/down channel will never bring you to 03, but you should be able to manually add the channel through the on screen menu system.
Alternately, simply punching in 03 (or 003) on the remote should force the TV to tune in channel 3.
Be sure the vcr is tuned to channel 3 as well, some are 3/4 switchable and default to channel 4 not 3.
A last resort if you can't get any of those to work is to get a cable splitter and run it in reverse with the 2 ended side going to the antenna and vcr and the single side going to the TV and doing another channel scan while the vcr is playing.
If none of these work, I'd need to know more about exactly how everything is hooked up.
ie - if the VCR is hooked into the component input on the TV, you need to switch the TV to A/V or composite or component rather than channel 3 etc. etc.
Posted on Mar 18, 2011
I get a no signal when I try to record
when the vcr is on can you see the program on tv? how bout when your press the tv/vcr button? is the cable connection plug in (vcr in from cable box/antenna and the out from vcr to tv).. both the tv and vcr should be on Ch 3.........
feel free to rate help
Aug 28, 2010 | Sony SLV-N55 VHS VCR
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
Input connections are not working properly. Some are black/white, some flash, some dont work. How do I fix it?
is your main antenna / cable (or cable box) connected to tv/monitor cable in...the monitor is on Ch 3...do you have dvd player or vcr...these devices must be set to cable / ch 3 also...and hook up to aux 1 or tv 2 depending on the jacks avail on the back of tv (please note if you are using a dvd recorder premium ch like HBO is and will be scramble)
Jun 14, 2010 | Polaroid 4011-TLXB LCD TV
It says "play" and my tv is on Ch.3 but there is nothing playing. I tried turning my direct tv off but it made no difference.
do you want to record programs on your vcr? connect the out to tv cable from your dir/tv box to antenna or cable in on the vcr, then connect the cable from out to tv on the vcr to antenna or cable in on the tv, you'll have to select channel 3 on the tv to get the vcr to show a picture and you will need to select channel 3 on your vcr to record the channel selected on your dir/tv box. confusing?thanks and good luck.
Jan 02, 2010 | GoVideo Go Video DVD/VCR Combo
Can not tape to vcr from digital tv
is there a cable/ satellite converter box involved? yes...line in from wall to converter box, line out of box to line in dvd / vcr and line out of dvd / vcr to the samsung note the dvd / vcr and samsung must be tune the ch 3....ok no box is involved...the dvd / vcr still needs to be tune to ch 3, (the ch is changed from the tv) dvd/ vcr line out should go to tv in.............the antenna/cable is plugged to dvd line in
have fun
Jun 19, 2009 | RCA Televison & Video
How to tune to tv channels
There is a switch [tv-vcr] somewere in the front.When pressed to tv, you can change the channels FROM the vcr.You will need an "air wave" ANTENNA signal because the cable box individual channels cannot be seen when you place the switch to tv.Now if you have a cable box connected properly and turn that tv-vcr switch to vcr the individual CABLE BOX CHANNELS will show through the vcr.
p.s. There is a small switch (someware in the back of the vcr & the back of the cable box,dish box, etc., etc.) ch.3 or ch.4 and the VCR have to be on the same INPUT channel as the box.
Dec 09, 2008 | Televison & Video
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Televison & Video Logo
381 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
