Question about Samsung Cell Phones
My handset Samsung GT-5300i can read the memory card installed but unable to read at Samsung NPS, what seems to be the problem?
How to connect internet with pc from mpbile samsung GT5300i
Posted on Mar 24, 2011
I have the New PC Studio for my samsung phone but i cant install it to my computer to put music in it. it says that i need to setup the NPS, which i dont know what that means or how to do it, PLEASE HELP !
If you just need to put music in it, you may try getting a memory card reader, insert your memory card and then transferring the songs through pc by connecting the card reader. Usually, the Music folder or Audio folder is where you place the songs and then it will be read and recognized by the phone once you insert it back.
Mar 08, 2011 | Computers & Internet
Even though i have installed the pc suite my samsung gt-s5233a does not coonect to pc
Try Samsung New PC Suite (Samsung NPS). Your phone will get detected automatically.
To connect to internet, add gadgets inside Samsung NPS.
Jan 07, 2011 | Samsung Star GT-S5233 Cell Phone
What does NPS not exist mean? I am trying to instal software for cell phone PC STUDIO Samsung. I also says must set up NPS. Please help Thanks in adavance JNM
You are referring to 1935 error ...
Is the system running in 64 bit or 32 bit ...
It would work on a 32 bit alone ..
You can tranfer files by
savefiles to memory card, not phone.make sure files are saved to memory card on phone, not internal memory.select mass storage mode on phone. memory card on phoneis recognised as external drive hence u could transfer files .
Apr 01, 2010 | Samsung SGH-J600 Cellular Phone
I have just got a samsung jet but can not put the soft wear on to my pc
to install your software to your pc, NPS, try to follow these steps. please take note that you don't need to connect your phone first during installation. if your phone is connected to your pc, disconnect it.
for xp operating system:
1. insert the cd to your computer...
2. enable autoplay for your cd / dvd rom drive
3. select appropriate language
4. select ''install pc suite''
5. once finished, select the finish tab
for vista operating system,
>>do the same as the above steps, if ask to run as administrator select yes.
>>after installation, uncheck run pc studio automatically after finish.
>>select install usb driver
>>click yes if prompted to run as administrator,
>>after installation, remove the cd, run NPS, and connect your phone.
>>if your phone can not be seen by NPS, do these,
on your NPS, click menu, select settings, select connection, check usb cable com1 or com 2 port select ok, and let your pc studio recognize your phone.
for windows seven, though the NPS doesn't support it right now. you can do the following tricks,
1. insert the cd, don't enable autoplay
2. browse your NPS cd, look for the setup for NPS..
3. once located, right click the setup.exe, select properties,
4. select compatibility,
5. check run in compatibility mode on win xp, win vista.
6. check run as administrator
>>during installation, if prompted that the installation was not successful it will give you an options, select install with recommended settings.
the trick also, if you can't install your samsung studio, you may do these...
on your phone, press menu,then select settings, select phone settings, scroll down and it will give you pc connections, select ask on connections, save and exit.
now, connect your phone to your computer, it will ask you what connection do you prefer, on your phone, press memory card, it will install your memory card as mass storage device, open it your my computer, you will see your memory card there, you can now, drag and drop files from your computer to your memory card.
there you go, hope this will help you so you can enjoy your jet.
regards...
Mar 08, 2010 | Samsung Jet S8000 Cell Phone
Can I load my pics and texts to pc and how do i save these to sim
to move your phone and pictures to your pc, do these steps.
note 1. if you didn't installed the samsung pc suite yet, do these.
>> if your pictures are stored in the phone memory, do these..
1. move all the pictures to your memory card.
2. insert your sd card to its adapter and insert them to your for laptop, sd card slot. for desktop, you need to have a memory card reader. by then it will be read by both pc and laptop as mass storage device and you can easily drag and drop files from both pc to your memory card.
OPTION (you can also do these)
1. configure your phone pc connections settings, check ask for pc connections, you can find the settings through, menu, select settings, select phone settings, select pc connections, check '' ask on connections''
2. connect your phone, it will ask for pc connections, select memory card, your computer will read it the same way as mass storage device, once read, you can drag and drop files from pc to your memory card.
i believe there is no way you can back up your messages by using your phone, not unless you have a program to do it, like PIM backup, or messages backup or something like that..
Note 2.
if you installed your samsung PC suite program,do these.
>> connect your phone, let it be searched by the PC studio, once connected, do the following.
1. open your communicator, select messages.
2. synchronize your phone message to the program,
3. highlight all the sms, mms(both inbox and outbox or sent) open the menu, select export to pc, once successful, the software will ask you where to save it. create a new folder (SMS backup) and save it there.
4. do the same way for your MMS, (both inbox and sent)
5. check the file in your computer NPS if the export was successful, you will find there the file which you had assigned a name.
>>to save pictures to your computer using samsung pc suite, do these..
1. double click your phone icon, the pc suite will read it, wait for it until it displays the panel.
2. from the panel, select files either from your phone or from your memory card.
3. once selected, highlight the picture images,press and hold and drop to the computer icon, the file will be saved from there. to check the files save, open your documents, default saving folder is not NPS but my pictures folder.
please consider that if highlighting images can not be done, then do it one by one, click and hold the images and drop to the computer icon. and to organize your file for immediate retrieval, create a folder from your NPS( you can see it to my computer my documents) and rename it as IMAGE BACKUP or your phone name_image back up (i.e; impression_image_backup)
Note 3. to transfer your files to your new cell, please consider this, if the phone your going to buy is not a samsung or the same brand as your previous phone then you will be having these effects,
1. the messages you have backed up will not be recognized by your new phone software program, then i advise you to copy your messages to your sim, the only advantage of it is, if your sim can only hold several text messages, hence you can not save all.
2. the phone book contacts may also not be recognized, hence i advice you to create 3 back up for your phone book contacts, A) make it as npf file extension for your samsung phone. B) the other as csv file extension C) outlook contacts or vcard extension file. you can select this in the drop down menu during saving or back up.
and to answer your question, you can't save your pictures to your sim, as your sim is not designed for it, unless, your network provider sim is providing this service.
you can check from your phone book settings, what is the default memory of phone contacts storage. for your pictures, you can check also from settings, just select memory settings and select default memory.
last thing, you can do the above steps for your new phone, the only difference is that, you will not be using the samsung pc suite, but your new phone's pc suite.
hope i answered your queries..
regards and take care.
Mar 01, 2010 | Samsung SGH-A877 Impression Cell Phone
I have a NPS error- 50 while installing the NPS for samsung mobile GT-S5233S... and when I completed the installation, It doesn't work !
Uninstall the only the NPS once and not the drivers of the USB or anything else, then install again let the Cd remain in the cd drive and try to open NPS. Your Issue will be resolved
Feb 25, 2010 | Samsung Star GT-S5233 Cell Phone
While installing the samsung cd,pc asks for nps settings.we need nps setup to install it. we want to transfer data from mobile phone to pc.
no need for cd justgo 2 settings then phone setting and the 2 last option pc connection in which do mass storage and connect and have fun and please vote for me
Jan 31, 2010 | Samsung Star GT-S5233 Cell Phone
Unable to load file from PC
1.) Select Memory Card in the handset : Main Menu > Multimedia > Music Library > Menu Key > Switch Storage Device > Memory Card.
2.) Connect the Handset with PC using Data Cable.
3.) You will get a prompt in the handset : Use as Mass Storage : Yes
4.) Go to My Computer, you will find a removable drive.
5.) Copy and Paste the Songs and Pictures in Removable Drive.
6.) Make sure that the keypad of the handset should not be closed during the entire process.
May 19, 2009 | Motorola Cell Phones
Unable to copy images and video from my Samsung D600 to my Micro SD Card 512mb kingstone
please select u r destination for camera as memory card. please rate this comment.
Sep 12, 2007 | Samsung SGH-D600 Cellular Phone
Downloading music
see if it got any driver and you didn't let us know you OS if it's xp it shouldn't happen .
Sep 08, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
199 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
