Question about Cell Phones
Ihave a supertooth voice which I can't connect to my new phone because I have lost the code number, any suggestions
  • mlmurphy Mar 18, 2011
    Thanks a million, have it sorted. What a relief, cheers Lesley
  • mlmurphy Mar 21, 2011
    A really prompt reply, thanks it is all sorted, cheers Lesley
  • 437 Answers
Hi mlmurphy yout code is 0000. id tghat doesn't wotk you need to use 1234. Your new phone has to be in discovery mode.hipr this helps
Posted on Mar 18, 2011
  • Cell Phones Master
  • 4,737 Answers
It's good to hear that your problem was fixed. I would like to request you to please accept the first experts solution by clicking the thumbs on the top (right) of his/her first comment. Clicking 4 thumbs indicates that the solution was helpful and your problem is resolved. If you don't do that, the first expert will not be credited. Hope you understand. Let me know if you have problem doing this.
Thanks for using FixYa.
Forget pasword for ST Voice SQ129 not 1234 or 0000
try your phone number or the last 4 of your phone number or change the code
Dec 06, 2013 | Blueant Supertooth Light Bluetooth Speaker...
How do I pair it to my droid two
Hi Amygreb4037
According to BlueAnt this is the correct procedure:
Firstly:
Make sure the Supertooth 3 is turned off. You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down. With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue. The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken. The Supertooth 3 is now in pairing mode.
Then on your droid two
Go to the system menu and enable Bluetooth Go to your phone's Bluetooth menu. Select Add New Device. Wait for your phone to search for devices, then select your BlueAnt device from the list. If you are prompted for a PIN, enter 0000 (four zeros). If you are prompted to connect to the device, select Yes or Connect.
The two should then be paired and working.
More information can be found on BlueAnts website:
http://www.myblueant.com/knowledgebase/pairing/products/st3.php
I hope this helps.
Mar 03, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
Hi, i have a supertooth light BTslbc3 and it has
Did you DROP the BTslbc3 from your old phone? If not, it may not pair with the new one. That is just a suggestion you may want to try. It may not pair with the new if it is still paried to the old. Hope this helps.
Oct 20, 2009 | Blueant Blue Ant 091193 Supertooth II...
I need the pairing key for a supertooth voice model n15417
I had the same problem but after hours on the phone to Supertooth found out you need to reset the device:
From off, press the Volume + button.
2- While you press the Volume + button, press the MFB (green button) for one second to switch on the kit. You can hear a special ringing via the kit. The kit says the Bluetooth and PIC versions. The Bluetooth indicator is blinking blue.
All pairings and phone books of the SUPERTOOTH VOICE are erased.
You have to do a new pairing with your phone.
Jun 07, 2009 | Blueant Supertooth Light Bluetooth...
Need to find out how to set up caller id on supertooth 3
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Pairing problem for Supertooth btslbc3
-----How to Create a new Connection----
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Goto Bluetooth menu on the phone (might be in connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Goto the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
Nov 19, 2008 | LG HBM-730 Wireless Headset
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
