Question about Electronics - Others
Have a True Life 6000e generator and it will not put any power out of any kind. When new ran for two hours and then quit generating. Don't have a clue what to do or what to look for so I can change the part.
    Sergeant:
    Champion:
  • 250 Answers
Make sure the square capacitor is not burned out or melted. Some of them had the capacitor under the rear end of the generator that has 2 screws holding it on. The other place where they put the capacitor is under the plastic cover on the main pannel. You have to take out 4 bolts and snap the plastic cover in the back of the pannel off. You would see if the cap is bad it would be melted and out of shape. You can use a electric mot capacitor 25 microfarid at 350 volts.I used to work on those generators quite a bit.
Posted on Mar 18, 2011
True life generator 5000e will run but want put out power
Try flashing the field - especially if it has been sitting for a long time. Look on YouTube for videos on how to flash the field.
Sep 03, 2014 | Electrical Supplies
Generator was running fine and then the electrical output quit while the engine was running.
Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
New generator bought on 2008 used for the first time 10/11, ran for about an hour and a half and stopped out putting any wattage, engine runs great...
This could be anything from a blown fuse to a shorted circuit. My best recommendation would be to have an electrician look at the generator.
Nov 10, 2011 | Electrical Supplies
I have a true life 4500 portable generator not enough voltage
where could i find a mot capacitor for the 4500 series and what do they cost
Nov 18, 2009 | Electronics - Others
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Generator quit working
i used to work at a repair shop for kohler 98 bucks an hour to check it out. and for them to repair who knows?. i would do my best if not in a hurry to figure it out on my own. you can purchsae a service manual and stick with your basics; spark gas, and from there go deeper.
Apr 26, 2009 | Kohler 12 kW Emergency Power System -...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Electronics - Others Logo
488 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
