Question about Garden
I need to know how to change the blade on the saw
  • 784 Answers
More details needed - Saw model.
Posted on Mar 18, 2011
How do i replace blade on kobalt 12dual bevil miter saw?
I don't know the model of saw you have but they are made for fairly rapid and uncomplicated blade changes as users will change the blade fairly often as they cut different materials.
Some saws have a spindle lock which once engaged means the bolt retaining the blade can be loosened with a single wrench and some saws need the spindle holding with a second wrench which is usually fairly thin, in the order of 3 or 4mm, to engage on two narrow flats machined on the spindle.
The blade changing process is a fairly intuitive one and if you take the time to turn the saw over and observe how it is assembled I think you will soon get the idea.
Feb 03, 2015 | Saws
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How to change mitre saw blades
you need to remove the "throat" plate and raise the blade fully. UNPLUG SAW FIRST there are 2 wrenches on the side one for the hex nut and the other for the arbor, the threads are standard. let me know if you need more assistance
Aug 25, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to change the blade? We have one wrench, but you need two correct? Where can I buy the wrench if I need one?
Well I use a wrench on the bolt and a screw driver in the teeth against
the table to stop the blade from turning.
You could also use a vise-grip to hold the blade, just be careful if you have carbide teeth so you don't break one.
Some saws have a blade lock on the motor, I don't know about yours.
I find it best to lower the blade so its just above the table so it can be held, and the bolt is out of the way of the table.
Feb 11, 2010 | Black & Decker BDTS200 15-Amp Table Saw...
Blade needs changing. nut is hard to get at
With the saw unplugged, retract the guard with the base plate extended so there is minimum teeth showing below. Place the blade of your saw on your wood top workbench. Press it down. Using the wrench that came with the saw or other appropriate size box or open end wrench or socket, turn the nut backward (this is a left hand thread not standard right hand thread). It will be tight.
Alternatively, there may be a shaft lock that you can press to lock the shaft to facilitate unbolting the blade.
Alternatively, there mau be a small hole in the blade. Insert a phillips screw driver in the hole to facilitate blade removal.
Key is knowing the thread is backward to what you expect. The reason for this is to cayse the nut to tighten as you turn on the saw, not loosen.
When you put on the new blade, make sure the nut is properly secured.
I hope this is clear for you.
If you have need for more information, please post a comment to this quesiton
thanks for your interest in FixYa.com
Please vote
thanks
a
Dec 12, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
