Question about Magellan Maestro 4250 GPS
Magellan 4250 fails to turn on. Have tried both car and home power supplies with same result. Its as if unit battery is bad.
  • 391 Answers
Hi depending on how old your system is its probably just your battery that needs replacement ,though it should work while connected to power source check the power inlit make sure it is not damaged or broken goodluck
Posted on Mar 18, 2011
Testimonial: "Thanks. Procurement or placement of the battery may be a problem."
My 4250 stopped talking. I ran the diagnostic
Probably a bad speaker, common problem with GPS units. Is there any sound at all, have you tried calling your cell phone to see if you can hear the rig through the GPS?
Try that and if you still can't hear anything it could be the speaker.
Feb 15, 2010 | Magellan Maestro 4250 GPS
I updated my magellan 4250 to v4.86 and now it will not work with the car charger. Screen states that USB is connected and I should follow prompts on PC screen. It work fine before the upgrade.
turn it on and hook it back up to the computer and once it has installed, use the safely remove hardware wizard to remove the 4250 from your computer, then plug it into your car again...if that fails, turn it on then try the reset on the side (little pin hole) use a paperc clip to reset it.
if you need further help, just reply to this post.
bill
Jan 20, 2010 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 needs a battery
There is a kit that includes battery, tools, and how-to video available here.
May 22, 2009 | Magellan Maestro 4250 GPS
WILL NOT TURN ON
Use a cell phone charger from motorolla razer, it is not wired correctly and the magellen turns on with an error, unplug the magellan from the cell phone charger and it will reboot.
Apr 25, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 GPS Power Failure
Hi guys. No need to panic. I thought I had the same problem when I got mine but actually there is no problem. Somehow, the off-on switch on the system is kind of funny. U really have to have small finger and depress the switch as far as u can until the system comes on. Might not be the fix you're looking for but give it a try anyway. Nothing to lose. Good luck.
May 18, 2008 | GPS
Magellan Maestro 4250 GPS Logo
468 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
