My RCA RTD325W system only plays DVDs in blue, yellow and white. Why? All of the connections seem to be hooked up correctly.
  • 500 Answers
Please check the connections according to the used video analog output with the figures below:
Composite video output (yellow connectors cable)
My RCA RTD325W system only - josema_sv_4.jpg Component video output (red, blue and green connectors cable)
Posted on Mar 18, 2011
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Why are my dvd's only playing in black and white? The surround sound system we have is RCA RTD325W.
Try purchasing a new video cord, or making sure that all your inputs are correct.
Mar 15, 2011 | Audio Players & Recorders
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Only reads dvds
I would try a System Update this seems to solve a lot of "Don't Play or Stops Playing" Issues. On the PS3 go to the 2nd Row from the Left in the Crossbar (Menu) Scroll up to the Top and click on Check for Update. If not then i would check how you have the system hooked up and if it is allowing 1080i or 1080p to pass through to the TV. Only Component (Red, Green, Blue cable) or HDMI will pass these signals to the TV! DVD's are 480i which the Yellow, White and Red cable they give you will not show HD!
Apr 21, 2009 | Sony PlayStation® 3 (80GB) Console
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
What are the functions of my input jacks?
The Y, Cr, Cb are referred to as "Component Cables". These are for enhanced quality. These connections must be used, at the min, for HDTV. THe Coaxial orange cable is for digital audio (used with a home theater system.
Dec 31, 2008 | Televison & Video
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
286 people viewed this question
 Grubhead
Grubhead
