Question about kawasaki Sport & Outdoor - Others
I have a kawasaki trans 4x4 4010, I think I might have knocked it out of line while pulling a tree out of the road, I backed over a small tree which snatched the steering wheel hard to the left, now when I drive the steering is nowhere close to being centered, and I'm afraid that is going to wear my tires on one side
  • 2 more comments
  • alxo13 Mar 18, 2011
    Is there anyway that I can fix this?
    also I need to know how to adjust the parking brake it will not stay down so that the brake light stays off and when it is started the shifter has to be moved alittle over so that the gears do not grind how can I adjust these things?
    these comments have been in generalities and not specific's, like diagrams, tools needed , time it generally takes to fix and the like, it said I would get step by step directions, if this is the best offered help I am not 100% satisified like promised
  • alxo13 Mar 23, 2011
  • 592 Answers
Hi.
I don't think it's your transmission that's out of line.
More than likely, when you backed over the tree, it knocked the alignment off for your tires.
A simple trip to the repair shop, get an alignment done, and you should be good to go.
If it is only one side of the tires that are out of alignment, then it also could be a suspemsion part, such as a tie-rod, a crossover bar, anti-sway bar, pittman arm, or still just a tire alignment issue.
You will want to have those things checked out as well, so that it gets repaired properly.
I hope this helps you out, and good luck !
Posted on Mar 23, 2011
  • kawasaki Master
  • 17,129 Answers
Need to have the suspension checked along with the front alignment of the wheels and steering . If this has moved or shifted from real value or damaged the frame to shift the alignment then it will require the precision setting to reset so that your fears of the tyre wearing.
Once the alignement is checked you can rest and be confirmed there are no issues.
Posted on Mar 18, 2011
  • Donald DCruz
    Donald DCruz Mar 18, 2011
    Provided you are mechanically minded to check at the damage and using the available tools at your end BUt do not attempt half heartedly so as to cause more issues.
    The hand brakes are to be readjusted to let the brake switch OFF. To me this looks as a resetting of the links, check for FREE PLAY and NON FRICTION of the LINKS. Your observation for a first hand view is important.
  • Donald DCruz
    SKill is the most improtant tool and I am trying to help you with the limitations on conveying an action which requires more logical assesment based on the damage on the equipment.
    Unfortunately the customer is the boss and I accept if your are not satisfied.
    Thank you.
2007 Kawasaki Vulcan 1500 loud knocking sound
Hi, Jeff I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Knocking Vulcan Noise Could be caused by damaged balancer dampers
Engine knock Vulcan Bagger Forums
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
Download Manual 2007 Kawasaki Vulcan 1500 Classic Owner Manual
May 21, 2017 | 2007 kawasaki Vulcan 1500 Classic
Can a shade tree mechanic change spark plugs in a 2006 buick lacrosse 3.8
Of course you can, you may need a few tools such as a spark plug socket with a flex attached and a few extensions 3/8 drive but other then that it would be just like any other car. Take your time doing one at a time and wha-la you are done.
First grab the back of the boot and twist a little left and right to break the natural adhersion between the plug and wire then slide the heat shield back and pull off wire, change plug and reinstall with dilectic grease
John
Jul 13, 2014 | 2006 Buick LaCrosse
How do i fix a rear diff the knocking when i put in in reverse or when i take off on hills sysyngog Kyron
I think you need to get some experienced help to identify the problem. You need to have the whole drive line checked from trans to axle, mainly because worn driveshaft joints can also give this noise. Before you get into the diff get it correctly diagnosed, could save you a small fortune? Get it over a pit and engage the trans in forward and reverse at idle, while someone is underneath to spot the noise. Park brake ON.
Jun 05, 2014 | SsangYong Musso Cars & Trucks
I have a Bob the Builder ornament holding a Xmas tree. Half the tree is gone leaving an exposed metal rod. How do I replace the lost tree material?
Hi, Hobby Lobby and other "craft stores" have mini trees. Also, small trees are used in model rail roads which can be found on E-bay. Buy the tree and twist it on to the old wire.
Jan 08, 2012 | Toys
My 86 olds cutlass has been sitting up for over a year, now i got it back on the road it won't get out of first gear. What can i do or check. HELP i love my olds.
Change trans fluid and filter. Sounds like valve body in trans is sticking. You might have to do this more than once to "un-gum"
Feb 23, 2011 | 1986 Oldsmobile Cutlass Supreme
1996 Chevy K1500 4L60E trans problem
O.k. the small hose that you have coming out of the case is the trans vent. The one going up the firewall is for the transfer case. The trans vent should be hooked to the transfercase vent. You say you have a 383? Are you running the fuel injection system. Is this a 4L60E (the stock transmission). If you have fluid coming from the vent, the transmission is getting too hot. Replace the cooler. Do away with the radiator cooler and add one to the front in front of the condenser.
Jul 22, 2010 | 1996 Chevrolet K1500
1994 Jeep Cherokee Transmission slipping when 4 wheeling.
lol dont run over trees! seriously check shifter connection under chassis if off twisting under load may cause it to move, trans over heating, or trans may be in need of rebuild
Jul 06, 2009 | 1994 Jeep Cherokee
2004 yfz 450 brakes don't work
The caliper probably got torqued and slightly twisted by the tree. This would restrict movement of the brake pad. No movement - no brakes. Pull the caliper and look at the pad as you apply the brake. No movement of the brake pad? Replace the caliper.
Mar 11, 2009 | 2004 Yamaha YZ 450 F
Oil leak
Hi, You don't say how much of a leak or if it is wet or blackened oil or if it is oil. Could it be brake fluid ? Clutch? I think before I pulled the trans cover I would remove alot of the fairing pieces and check for loose bolts, clamps, clips, check hoses, seals and overflows. Check levels to see what is low or maybe too full. Don't look for problems that might not be there! Find your source first! Good Luck!
Feb 15, 2009 | 2000 kawasaki ZRX 1100
Sport & Outdoor - Others Logo
27 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
