Question about Coleman Heating & Cooling
My coleman furnace in my rv just quit blowing it stays lit but the blower doesnt work it is a coleman presidential
    New Friend:
Mmmm, if im you check if the fan motor has voltage ,if it does, check mfd at the capacitor to see if is the right one.if it doesn't change capacitor.
If you dont have voltage at the fan means the board is not calling for it. Jump the temp switch and it should start.
Posted on Nov 25, 2016
    Sergeant:
  • 259 Answers
It could be a bad temp sensor that tells the fan to come on when the heater reaches a certain temperature or it could be a bad fan motor. Take a 12 volt jump start box and hook it directly to the fan motor to see if it will spin. If it does not the motor is bad and if it does you have to replace the temperature sensor in the heater.
Posted on Mar 18, 2011
Coleman presidential furnace
bad fan control switch or bad fan motor
Nov 28, 2017 | Coleman Heating & Cooling
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
Jun 05, 2017 | Heating & Cooling
I have an old Coleman Presidential propane furnace. The other day the furnace quit working. I checked and the pilot was out so I relit it and positioned it back to on. The main burner then ignited but only...
Try taping assembly the pilot with a screw driver sounds like a dirty pilot and when the flames come on the pilot pulls away from the thermal couple but tap it when the pilot is lit not the burners
Mar 22, 2013 | Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
Nov 01, 2009 | Heating & Cooling
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Heating & Cooling Logo
251 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
