Question about Soundstream Car Audio & Video
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Posted on Mar 30, 2011
  • Clinton Bacote Apr 14, 2011
    Katobuzz responding thanks tips help. I will try your way. I believe owner man. gave a diagram for your set up. Just have to research my woofers
I have 4 rsd65cs Phoenix gold 6.5 components 4ohm stable & 1 06S10L74 kicker I want to run it at 2ohm. A lil overpower is fine as I can always turn down.what is the best Option 5 channel amp? Thanks
sounds like you need to get a 2nd amp for the woofer, then bridge the two amps but be sure to adjust the output mode to lpf for your woofer and hpf for the 6.5s. hope this helps.
May 04, 2015 | Kicker Car Audio & Video
I got 2 pcs of kicker 12L7, one is 2ohm and the other is 4ohm DVC. in there any chance i can run them together with one amplifier? i got a venom VD2600S and venom 1600.D, will it be ok if i use each...
Run the amp in stero Run the 2ohm to one chanel, Wire the dvc 4ohm to run 2ohm + to + - to - to the other chanel and you should be fine.
If you had a 1ohm stable amp you could run both speakers wired 2ohm to a mono amp and have a 1ohm set up and double the power!
Feb 04, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
I have two 15inch l7 subs 2ohm
With 2 ohm dvc a sub can output either a 1 or 4ohm load.therefore with 2 subs you end up with 2ohm or 8ohm load.Of course you'll use the 2ohm connection which is this.....
Take one sub and connect the (-) with the other (-) and the (+) with the (+).
Do the same with the other sub.Each sub now carries out a 1ohm load and you end up with 2 pairs of cable.Now take one(+)and put it on the amp.Take the (-) from the OTHER pair(this is critical) and connect it on the amp.You will still have a(-) from the first pair and a (+) from the other pair!Well....connect them together!!!Thus you'll have a 2 ohm load on the amp!
Nov 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Nov 19, 2007 | Car Audio & Video
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
188 people viewed this question
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
