Question about Kenwood DNX6160 Car Video Player
HI, I HAVE A DNX6160 AND HOOKED UP THE BACKUP WIRE TO THE BACKUP LIGHT BULB WIRE IN THE TRUNK. THEN HOOKED UP THE YELLOW WIRE TO CAMERA AND PLUG ON BACK OF HEAD UNIT. THEN HOOKED UP BLACK WIRE FROM CAMERA TO GROUND AND RED WIRE TO BACKUP LIGHT BULB WIRE. CAMERA DOES NOT WORK. CAN YOU HELP?
  • 391 Answers
Hi judging by your wirering it seems to be ok did you check to see iff there was power going to the camera or the camera could be faulty also check all power leads with metre if you have one if not get a 12volt bulb and connect you reverse wirering to it or check for breakage in wire going to camera its most likely a power fault ,or camera faulty goodluck
Posted on Mar 18, 2011
  • this is a scam website Mar 20, 2011
    hi so what was the outcome of the camera ,was it faulty or no power
I installed an aftermarket backup camera on my09 chev Silverado. Camera works fine if staight 12 applied, but will not work when hooked up to backup light .Any suggestions?
Your problem there may be that your back up lights are not getting 12v to the system, if you have a multi meter you can test how much voltage it getting through the wire, also maybe the camera is not being wired correctly into the backup light or there is a shortage somewhere in the wire.
Apr 08, 2017 | Cars & Trucks
I AM ATTMEPTING TO CONNECT A WIRLESS BACKUP CAMERA AND NEED TO IDENTIFY THE WIRE THAT POWERS THE Backup light - Can you get me the wire color combo plase
Pull the light assembly out on the side you are going to tie into. Pull the bulb out of the back up light. look at the center of the socket and that is the wire you want tie into for your power up to the the camera.
Jan 23, 2016 | 2006 Toyota Camry Solara SLE
The rear turn signals hazards and break lightsand reverse lights work but the tail lights will not come on why is this
The signal/ hazard and break light use the run on the same wire The backup light use a different wire and bulb. The tail light use a different wire Check wires and connections
May 31, 2015 | Cars & Trucks
Installed reverse camera to Eonon E1025 unit. Power for the camera was taken from the reverse lights (positive and negative). Video wire from camera was taken back to the E1025 unit. I expected the orange...
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
Nov 28, 2010 | XO Vision XOD1735 Car DVD Player
How do i replace the rear window brake light?
Hi, throw the trunk right under where the light is mounted, there should be two wires. Grab and turn the plug at the end of the wire, the plug with the bulb should pop out.
Aug 12, 2010 | 1996 Lexus LS 400
How to change the third brake light.
1.) unplug the connector in the trunk (its a small white plug running up to the third light, there should be a small clip you squeeze).
2.) remove the 2 gold-colored screws from inside the trunk. They can be seen from the trunk. 1 is thru the larger square opening where the wire connects to the 3rd brake light. The 2nd is on the right side thru a small (screwdriver width) hole covered by a piece of foam tape stuff I had to punch me screwdriver through the foam to get to it.
3.) after removing the 2 screws, go inside the cabin and the brake light housing pops up.
4.) disconnect the bulb from the housing while inside the cabin (I had to do this with me two forefingers since the housing only pops up and inch or two).
5.) in the trunk remove the wire and bulb. (it's about 5 inches long. the wire from the connector to the bulb socket)
6.) reverse steps to install.
It is a pain and reqiuires a bit of time only because there isn't a lot of room to move around, but it beats taking it to the dealershio!
Nov 20, 2009 | Hyundai Sonata Cars & Trucks
Replacing a brake light Tercel 1999
1999 Tercel rear light bulb replacement. Snap off 2 black caps to pull back carpet. Remove 2 screws on outside of trunk at the edge of trunk lid. The light fixture will loosen up. Sqeeze the tongs on the square white plastic plug on the inside and push plug through hole. You may have to give the light fixture a tug. Turn bulb holder and pull it out. Pull out bulb and put in new one.
Apr 02, 2009 | 1997 Toyota Tercel
LS400,1996,replace rear window brake light bulb(s).
THREW THE TRUNK RIGHT UNDER WHERE THE LIGHT IS MOUNTED THERE SHOULD BE 2 WIRES GRAB AND TURN THE PLUG AT THE END OF THE WIRE THE PLUG WITH THE BULB SHOULD POP OUT
Mar 30, 2009 | 1996 Lexus LS 400
Wiring diagram for reverse light
Splice the camera power wire into one of the backup light bulb sockets at the rear of the car. Make sure there is a good ground connection to the camera housing too. It's best to add a ground wire so there will never be a power problem at the camera.
Apr 09, 2017 | Hyundai Motor 2005 XG350
Tow plug
I take it the blinkers and brake lights work ok when not hooked up to the trailer? If yes, then the wiring to the tow hitch is not hooked up correctly. How many wires to trailer pig tail connection? U can have up to 7 depending on what you tow. Check to make sure these wires are hooked up from the truck to tow plug correctly: 7 wired---
brown-Rt turn and brake light, yellow-backup, white-ground, blue-electric brake, green-tail running lights, black-battery charger, red-left turn signal and brake light. Let me know if u have something other than 7 wire, I'll get the wiring color and source info for u.
Nov 25, 2008 | 1998 Ford F150 Regular Cab
Kenwood DNX6160 Car Video Player Logo
218 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
