Question about Vacuums
Replaces the belt on dirt devil dynamite pluse model put everything back together started it and it burt the new belt up that fast. I put it around the beater brush and the metal bar I thought it should go around, yet it seemed like there should be something else there to put the belt on. What do you suggest? Do you have picture I could go by?
    Sergeant:
    Champion:
  • 250 Answers
The metal bar you put it around if the bar itself does not spin it is going to burn the belt up. Every thing that the belt is supposed to go around has to turn or the belt will rub on the piece not moving and brake.
Posted on Mar 18, 2011
  • dbardwell Jun 22, 2011
    is there suppose to be a pulley on the metal bar in the rear like the idler arm? or simply a straight metal bar?
  • Tim Venetis Jun 22, 2011
    I don't remember exactly what is on there but I would think there should be a pulley to keep the belt in line.
How do I keep the rear wheels from coming off my dynamite upright dirt devil
Plastic to plastic wears fast. I have repaired this problem by inserting small wooden dowels between the splits in the axles.( I have one of these machines in my home) Lubricate the axles with a non-petroleum grease afterward. I use Superlube available in most auto parts stores.
Nov 21, 2014 | Dirt Devil M084600 Dynamite Bagless...
How do I change the belt on a dirt devil dynamite II cyclonic
Hi! Happy to help with that. Please follow the steps below.
  • Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the three (3) screws.
  • Lift and remove brushroll. Dispose of old belt.
  • Slide belt onto motor shaft.
  • Place new belt in area of brushroll without bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end cap on the left is in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
  • Reattach nozzle guard by carefully sliding back into place. Interlock rollers and nozzle guard by tilting rollers down towards the base while replacing the nozzle guard.
  • Be sure to replace all three (3) screws.
Hope this helps!
Oct 12, 2014 | Dirt Devil Vacuums
Belt drive keeps melting every belt we put on
usually that means something is stopping the brushes from spinning weather it is not greased well or just something still there I can't tell you but that is the broblem. You could try asking in a vac store/repair if they've had a fair amount of that model doing this and reccomomend a slightly different size .thickness belt to take up some slack
May 17, 2010 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil- Brush not rotating on its own. No suction.
drive belt. take housing apart (draw a diagram so you can put it back together) take the broken belt to a vacuum repair shop to get the same one. mine cost 7$.
15 minutes work.
Jun 14, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
D.d vaccum
Did you check the brush roll, if the ends aren't turning freely, then it needs to be replaced also.
Mar 20, 2008 | Dirt Devil M084600 Dynamite Bagless...
Describe your Dirt Devil M084600 Dynamite
u all ready try taking botem off to getto it no luck ?
Feb 10, 2008 | Dirt Devil M084600 Dynamite Bagless...
Ear piercing whistle
Its an inherent problem with any Dynammite model = the fact that the motor is at the front means that it is extremely noisy.
Sep 30, 2007 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
