One of my disc drives on my Dell Dimension 8400 is stuck open. i have a Lite on Model LTN-486S that i took out of a Dell Dimension 4800 that was broken. is it compatible with mine?
    Novelist:
  • 117 Answers
Here are the simple information that you need to know.
First check the Optical drive if it is an IDE device, check on the back of the drive and you should see many pins for the connector, here is what it look like, if it is then it is compatible to your Dell 8400, as these computer uses IDE for optical drive. If you want to know how to install your optical drive to your 8400, here is the link that can help you with step by step and visual instruction.
I hope this will be able to help you.
Thank you for choosing Fixya.
Posted on Mar 18, 2011
  • 356 Answers
Should work fine. Only issue you may run into is getting the cable settings (master / slave) set up so everything shows up. Most likely if you're replacing an existing one you can get away with just setting the new drive to cable select or what the previous drive was set to though.
Please leave feedback if this was helpful.
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
Need to replace my cd drive. what kind of cd drive is compatible? Will any brand work such gateway? It is a lite on LTN 489S. Dell dimension 3000 desktop.
Yes MOST any cd drive will fit in MOST all computers and it is easy to do which you will see when you open your computer. but if not just text me back and i'll help you:)
Jul 26, 2011 | Dell Dimension 3000 PC Desktop
I lost the driver
It does not look like it burns CDs. Here is the Features of the LTN-486S.
  • 48x CD-ROM with Pure-CAV Technology.
  • E-IDE Interface, support all PIO, MW-DMA, Ultra DMA-33 modes.
  • Support Power Saving Function.
  • Support High Speed Digital Audio Extraction ( DAE ).
  • Support High Speed VCD Data Extraction.
  • Support Plug & Play; Emergency Manual Eject.
  • High Speed CD-Audio Playback Technology to Improve Audio Playability.
  • Access all format CD, CD-R, CD-RW Title & Disc ( support up to 99 mins ).Easy-TrayR Design for both horizontally & vertically use.
  • Gear-Driven Tray Loading Mechanism to improve reliability.ABS Auto Balance System ( 486, 485 ) Mecha to Reduce Vibration R Noise.
  • WSSR Wire Suspension System ( 483 ) Mecha to Reduce Vibration & Noise.
  • Jul 01, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
    Can't install WINDOWS.
    Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
    Mar 11, 2009 | Dell Dimension 8400 PC Desktop
    No video
    you can try to hook up everything back up and then take out the video card and clean the place that it llides into and the card itsself and reinsert it and see what happnes but please make real sure that u connect everything back just like it was cause if there are cablkes that are switched there will be problems
    Aug 19, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
    CD-ROM will not read any disc
    well try to clean the lens with a clean and dry cotton swab. ir you have a compressed air duster for electronics, use it also. remove the drive and open the cover. look for small like circle glass(lens) clean it. use also the compress air duster by hitting the below parts of the lens assembly to remove accumulated dust and test. if the problem persist, its about time to replace your drive. good luck!
    Feb 06, 2007 | Lite On LTN 323 (LTN-323) Internal 32x...
    Computers & Internet Logo
    26 people viewed this question
    David Payne
    David Payne
