When someone from the outside tries to fax they say the line is busy
    Problem Solver:
  • 7 Answers
When this happens you may have to contact your network provider or subscriber to fix the problem. The phone line is probably faulty and it could be a technical issue. However if it is a cell phone you might have touched something on the settings that makes the phone to be bussy whenever someone calls. you can go back to the settings and make sure that it allows incoming calls and that they are not bared.hosea
Posted on Mar 18, 2011
I am trying to fax, but I keep getting a "busy"
Make sure you have pluuged the telephone line lead into the "LINE" socket and not the "TEL" socket of the fax machine. I reckon thats why you are not dialling out correctly. If this is in an office, make sure you are dialling the access number for an outside line, usually a 9 before the phone number.
Jul 19, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
I cant fax
Take your cell-phone, and dial the same number, to see if you get the same "busy" signal.
If the telephones in your business require you to "dial-9" to get an "outside" line, be sure that your FAX is also following that "dial-9" protocol, and also waiting 1 or 2 seconds after the "dial-9", in order to get the dial-tone from the "outside" line.
Dec 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
Mar 23, 2009 | NorStar M7324 Telephone
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Fax
If you have dial-up for your internet access you cannot be online when a fax is coming through. The line has to be free to receive the fax.
May 03, 2008 | HP PSC 950 All-In-One InkJet Printer
Dialling out!
Hi make sure that you don't need a prefix number i.e. a 9 to dial a outside line. The best test is to plug a normal phone into the socket and call someone from that line. If the same problem is still there then it is a line problem if not check within the machine menu that under TTI or call settings that there is no prefix number installed. If there is set the machine so it doesn't need a prefix.
I hope this helps you
Thanks J
Jan 06, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Brother Intellifax 4100
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
Computers & Internet Logo
David Payne
David Payne
