Question about Samsung RS2630SH Side by Side Refrigerator
The screen where water and ice come out says OF OF
  • Samsung Master
  • 4,655 Answers
F0 Function key stuck Replace touch pad (ERC). FO has a broad range of meanings so the board behind the keyboard may be defective. You should check for loose wiring connections at board and also where wires go through door to cabinet. Here is some larger breakdown's of the fountain=> RS2630SH Fountain Components If you also would like assistance in diagnostics and repair of your fountain I can assist you there. Let me know what part of the diagram you will need. At this point I believe the problem is local to keypad and board behind it. Thanks, Sea Breeze RS2630SH_User__Manual
Posted on Mar 18, 2011
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Ice maker is not producing ice and the control light is blinking red
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Ice maker makes hollow ice
Not enough water. Check water filter if you have one and replace. Check water inlet valve pull supply line off of water inlet valve and make sure the screen in the water valve is not stopped up. make sure water line is not kinked.
Jul 11, 2014 | Marvel Appliance Ice Maker
The ice making part of my ART 745 fridge freezer is not working is does not appear to be getting any water to the ice making compartment the machine is working normally otherwise can you please advise me...
Hello there,
When your ice maker is not getting water into it, it simply means the water inlet valve is clooged with dirt and have blocked the valve from getting water into the ice maker.
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer.
An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
You should also test and replace the defrost thermostat if the water inlet valve is cleared out. To test and replace the defrost thermostat. Please click on the link below to be able to test them yourself: http://www1.fixya.com/support/r10513592-test_defrost_thermostat http://www1.fixya.com/support/r10513650-replace_defrost_thermostat
If that does not solve the problem, then you will have to replace the ice makers mechanism.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker is not getting water to make ice
Hello there,
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer. An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Sep 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My ice maker has stop working .mod FRT21TNGD3/FRIGIDAIRE
First need to determine water supply. Water filter and or inlet screen fouled? I know this is assuming the water supply is open..
Check the ice level bar to be sure it is in the correct position for making ice. If it is incorrect poition, the ice maker "thinks" the ice bin is full. I would start there with the water supply though. Most likely...
Jul 21, 2010 | Frigidaire Refrigerators
Ice maker not working water is connected line is not kinked temperature is right
You have not provided a make or model so I am going to assume this is the standard half crescent ice cube maker. Your Ice maker has a little wire arm that must be in the down position to begin making ice. If that arm isn't down then do that now. You could have other problems such as, the ice maker motor isn't cycling or your water valve is stuck or dead etc, so lets address those issues now. To test for proper Ice maker motor operation try adding 1 cup of water to your ice maker and allow it to freeze 45 minutes without opening the freezer or fridge door during that time. Verify that your ice ejection arms are facing a close to level posotion in the ice cube tray itself. That's the little fingers you see sticking up in the air as ice is ejected from the ice tray. Now pour the water directly into the ice tray itself and wait for it to freeze and be dumped. if within a 45 minute to 1 hour period, there has been no movement or ejection of the frozen ice cubes, you may safely assume that your ice maker is either dead, or simply not plugged in completely or correctly. If however the ice has ejected we can move to the next step, the water valve. Sometimes the electric water valve (solenoid) screen becomes clogged and must be cleaned out for water to flow. Follow the water hose at the back of the fridge from the top of the box to the little blue or red valve (solenoid) at the bottom of the fridge, or you may simply follow your fresh water line from your line tap to the fridge itself, turn that off and remove it. Now inspect and clear any obstructions you see on the screen. With a helper on the other end, have them turn your water tap on at the source to check for water flow using a cup or mop bucket to catch the water as it comes out. If all is well water flows and the screen is clean and you may now reattach the fresh water line. Now we test the solenoid. This test requires a standard carpenters nail and a block of wood. Placing the wood as close to the solenoid as possible, while keeping it flat and level, take the carpenters nail and place it as close to the water valve/solenoid as possible while standing it on it's head on the block of wood. When the solenoid trips the nail will fall over and you will hear it hit the floor. When that happens you should hear water flow into the ice maker. If no water flows, your solenoid is jammed and needs to be replaced.
Mar 13, 2010 | Refrigerators
Poor quality ice
Is the ice too small or is it dirty in appearance? If it is too small then the 1.4 inch water supply line may be pinched or clogged. Trun off the water to the unit and remove the line connected to the rear of your fridge. Then get a large bowl and have someone turn on the water supply. If there is sufficient pressure then more than likely the inlet screen to the ice maker water valve is obstructed and will require cleaning. Follow the input water line to the ice maker water valve. Some valved can have the screen cleaned with the valve installed by removing the input line and then the input screen. You can gain access to the screen by removing the flexible back panel, remove it by using a pointed tool on the outside of the screen ede only. Then wash / or scrub it clean with your fingers while running water over it. Reinstall the screen, reconnect the valve input line and then reconnect the water supply line and turn on the water supply. It can take several hours before the unit starts making ice cubes again as you have intorduced air into the system and it will self purge during the next few ice making cycles. You should have the correct sized cubes within 24 hours. If the cubes are dirty then go to any appliance parts supply store, purchase a charcoal filter and install it just above the inlet supply line connection.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is not working. No water is getting up to maker. Ice maker sounds like it is working. Tube in back has no water in it.Arm is down. Water is coming out of door just fine. There is no built in...
There is a screen in the water inlet valve where the water supply connects. OR The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 20, 2009 | Refrigerators
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
105 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
