Blows 0.8A small fuse (right next 2 power supply Input from mains power) every time it's replaced. It stopped powering up one day & ever since, hav'nt been able 2 power up d unit.
  • 1 more comment
  • colossus339 Mar 18, 2011
    Hi.
    I'm terribly sorry it's a Hotpoint, model # HPDP42 made by Samsung I believe.
    If I may ask. what's that roughly worth (US or AU $ are fine)
    thanks
    Could u kindly at least provide me with a part # of some type as I've been searching the site 4d last 30 mins,
  • 10,594 Answers
Let me know model number and brand info of tv to find out possible cause of fuse blow and to suggest a solution.
Thanks.
Posted on Mar 18, 2011
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Mar 18, 2011
    OK, it seems standby power supply circuit is defective and blowing fuse, please replace power supply board to solve tv problem.
    Thanks.
    I'm afraid, I do not have exact idea about power supply board price, it could be US$120 or so, however, please check with Bigwarehouse.com.au about required power supply board because they are big supplier of tv parts in Australia.
    Thanks.
    Part number would be written on power supply board, please check power supply board of tv.
Hp p1005 stopped working
Printer switching on?.Might be power supply failed, replace Power supply board.if you are tech guy..Open left,right & back doors. Check input fuse.. if fuse open replace with same rated fuse, give power, check.. if again fuse is open replace power supply board. if its OK wait few minutes & confirm.. fix it back..
Nov 28, 2011 | HP LASERJET P1005 Printer
Input fuse blows on switch on
In most power supplies, if the input fuse blows that fast it's because of some shorted component right at the AC input. Check for shorted rectifier diodes and filter capacitors. Both are common failures, especially if the equipment has been subjected to power line surges. If the power supply checks out OK, shorted output devices in the amplifier section is the next most likely cause. Check for low resistance on the outputs of the power supply. It's helpful to have a schematic diagram of the receiver for troubleshooting, and you can often service manuals or other information free or at reasonable prices on the Internet.
Jun 25, 2011 | Cambridge Audio Audio Players & Recorders
When right channel is wired it shorts out the power supply. Aragon 8008 when powered up without input and output, no problem. When connected with speakers and line level feed in, the left channel works...
Fuses blow when there is an overload caused by a short circuit. If the speaker you connect up to the amp causes a short. There is either a shorted part in the speaker or the wires to it are touching at some point. Assuming you can sort out the speaker issue and connecting a good speaker with good wiring and it still causes a short and blows a fuse. Then it's likely the output device(s) in the right channel have developed a short themselves. Perhaps as a result of being connected to faulty wiring or speakers.
Jul 18, 2017 | Aragon 8008 MK II 2-Channel Amplifier
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Short Circut, blows fuses instantly.
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Jul 28, 2008 | Durabrand 5.1 Surround Sound Computer...
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
