Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Glasses in top rack do not come clean - Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
  • 10,865 Answers
Hello loria... When the top rack no longer cleans like it should check the flexible hose in the rear of that tray for holes. It may even be disconnected, or not lining up with the water supply connection in the rear of the dishwasher.
Check these things, repair or replace as necessary and you will have clean glassware once again. Joe
Thanks for choosing Fixya!
Posted on Mar 18, 2011
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Posted on Jan 05, 2009
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
  • 3247 Answers
SOURCE: my dishes are not getting clean, especially the
The problem in the top drawer could be due to a few reasons.
Have you cleaned the wash arm and does it sit in alignment with the hole from which the water comes in.
Try to increase the quantity of detergent and rinse aid to see if there is any difference to the cleaning of the glasses.
You can check if water is getting to the top rack by leaving a container in it to measure the quantity of water at end of wash cycle. The gritty substance is usually the sand in the detergent. It is left behind because there may not be adequate water reaching the top rack.
Once in a few months you should use a Finish Dishwasher cleaning kit and run the empty dishwasher with it according to the instructions on the kit.
Hope this will help solve the problem.
Posted on Aug 29, 2010
My dishwasher doesn't clean the all the dishes, esp on top rack
Check the jet holes on the sprayer arms. The outside holes usually plug first from calcification and centrifugal force causing only the center areas to clean. Remove these arms and shake out all of the "little white rocks" and then run the machine empty with a de-calcifying cleaner.
Sep 15, 2014 | Bosch Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Nov 25, 2008 | Dishwashers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
134 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
