Question about Bose 3·2·1 II System
I hooked up the cords exactly as picture and when in dvd input the picture is in black and white. I tried movie the yellow video chord to every single hole on the back of my tv and it doesnt go to color?? The yellow chord is in the composite hole of the bose.
    Brigadier General:
  • 8,546 Answers
If you tried the yellow composite cable "in every single hole" it wasn't exactly 'exactly' following the manual then, was it?
Are you using component cabels, too (red, green and blue). Mis-wiring them will give you B/W or other wierd visuals.
Your TV's inputs and what is selected by the TV's controls would determine which cables' input it display. You could prove whether the composite is the culprit by removing it while viewing the TV. If the picture goes away, THAT cable is carrying the video you're watching. Otherwise, maybe you need to select the component input and check the conenction of each wire while watching.
Posted on Mar 18, 2011
I just bought a 40"
you are trying to hook up composite to component. the component green is your y video or black and white getting b and w proves your component is working plug up red and blue make sure your dvd player has component out have to use seperate audio for component
Jul 18, 2011 | Televison & Video
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
Jan 13, 2009 | Samsung T220HD LCD Monitor
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Jun 17, 2006 | Sony DVP-NS700P DVD Player
Bose 3·2·1 II System Logo
75 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
