Question about Canon Cameras
L have a canon g 9 bought in april. camera went dead on me, tried two batteries but no joy
Camera being returned as still under warranty
thanks
lynn
Posted on Aug 02, 2008
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Aug 10, 2009 | Canon PowerShot SD1000 Digital Camera
Not powering up and batteries are good. the little blue print light was blink at some . that was the only sigh of power at the camera. Neil
Suffering the same problem Neil. Tried removing cmos battery, no joy....tried 3 different batteries, with and without grip, still no joy.
Anyone got any ideas before i book it into camera hospital?
Cheers,
Al
Aug 04, 2009 | Canon EOS 40D Digital Camera
Camera will not turn on. was working and went
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI, I THINK I HAVE TO SAY THAT YOUR CAMERA IS DEAD RIGHT NOW,A VERY LITTLE YOURSELF CAN BE DONE.YOU HAVE TO TAKE IT TO SERVICE STATION.BECAUSE OF SOME MALFUNCTION THE POWER SECTION OF YOUR CAMERA WENT OFF.BUT DON'T WORRY IT CAN BE RECTIFIED.
Aug 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I purchased the camera in April of 2007, but have only taken about 500 pictures. Today I turned it on, and when I tried to take a picture, the message "change the batteries" came up, and it went dead. I...
It is likely that an internal integrated circuit in the DC/DC board is damaged. Either an electronic component just is worn out, or moisture or humidity affected the camera. You can try with a different set of batteries (different brand and type) since such DC/DC converter board has a monitor circuit of the battery level, and when the components of it start failing, gives a wrong battery level to the micro-processor. If after try other batteries you have the same problem, then you will need to have your camera reviewed by a qualified technician to have it repaired, since it requires open the camera and evaluate the DC/DC board performance.
Best regards,
Jul 12, 2009 | Canon PowerShot S3 IS Digital Camera
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
Canon A95 gone dead
Canon customer support will tell you what exactly what is going on[or not] I suspect a circuit failure- if the camera is out of warranty then a new camera will probably bt the answer.
May 29, 2007 | Canon PowerShot A95 Digital Camera
Cameras Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
