Question about Casio DR-210TM Calculator
How do I set the date and time? The manual does not really make any sense.
Ferrari World Time watch setting, manual is awful and useless
You have to hold down B to set up T1 which is the time the hands will display. Once you see the City and T1 show up on the digital display you can go through the various settings to set time/date etc. Use B to cycle through setup and A to make the necessary changes.
Pushing the crown allows you to set up T2 or the time displayed on the digital section. You set this by choosing the time zone.
Hope this helps
Jan 05, 2015 | Ferrari FE-05-IPB-FC World Time Mens...
Intellisense electronic blood pressure monitor
Hi Linda, This is from an Omron Intelli sense model HEM=7211, They look the same so I hope this helps.....CHEERS..
Oct 12, 2014 | Health & Beauty
I have a Timex automatic with day and date. How do I set the day and date?
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!
I'll try to explain the process - please feel free to contact me if this doesn't make sense.
1. Pull out the crown on the right hand side of the watch.
2. Advance the crown so the time advances clockwise until the day is correct.
3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).
4. Rotate the crown so the time is going clockwise again and the date will advance.
5. Continue this back and forth action of rotation until the date is correct.
6. Push in the crown and you're done!
I'm considering making a video of this process. Please let me know if this is something you would be interested in.
Oct 30, 2010 | Timex Automatic Watch
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
The time and date on my garmin are off....the time reads 9:30pm when its really 10:30pm and it says the date is november 7, 2029 when its really march 24, 2010....how do i resolve?
See this link to the garmin web site to set your time
http://www8.garmin.com/support/faqs/faq.jsp?faq=24
Manual download is here:
https://buy.garmin.com/shop/store/manual.jsp?product=010-00621-31&cID=164&pID=37417
Mar 25, 2010 | Garmin nuvi 260W GPS Receiver
Is there an internal battery for the time and the date?
Manual says: "After installing the batteries, the set-time/date message may appear on the monitor. The clock and calendar are set in section 3 of the setup menu (p. 18)."
In fact if you replace batteries really fast (in a minute or two) and time is reset the internal battery is probably exhausted/broken. You have to decide if it is worth of repairing.
My Z1 has 6 years and the clock does't forget time. Maybe next time i'll be surprised...
Mar 13, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
Wrong time
To set the time do the following:
Setting the date and time
Press the Back/Options button ((the left pointing green arrow)).
You may need to do this more than once until the main menu appears.
Select Extras Date & Time. The current date and time are displayed.
Press and hold the Back/Options button.
Select Set Time or Set Date to change the time or date settings.
Select Date Separator, Date Format and Time Format to adjust how the date and time are displayed.
Select the options you want.
Mar 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Unable to set time and date on a vestal G5 global traveler watch
Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
Jan 23, 2008 | Columbia All Sport Digital watch
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
Aug 10, 2007 | Luminox Navy SEAL Dive 3103 Wrist Watch
Casio DR-210TM Calculator Logo
184 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
