Question about ASUS U52F-BBL9 Laptop
My laptop does not work when connected with an HDMI cable to my HDTV. I can't see the laptop Display in the TV
    Problem Solver:
  • 13 Answers
You may have to enable this option within the software on the computer before the TV will work. Try right-clicking on any blank spot on your desktop, a context menu should appear. See if there are any entries that have the words "ATI", "Nvidia", "Catalyst", or "Control panel". You may find the appropriate options from there.
Posted on Mar 18, 2011
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
No signal when I hook my Dell XPS laptop to my Element HDTV
turn off tv and laptop. connect the hdmi cable to your tv and laptop turn tv on then log onto your laptop Both devices need to be off when connecting the hdmi cable
Apr 13, 2013 | Dell XPS Computers & Internet
Connect protege to viera
You are trying to connect laptop to a tv, right? Does the TV have any compatible inputs? VGA, DVI, HDMI
Your laptop has HDMI output and is Intel Wireless Display Capablewhich means you can get an adapter that supports Intel Wireless Display and wirelessly project multimedia to your HDTV with great image clarity and sound.
If your TV has HDMI input, buy a cable and hook them together. Otherwise you can buy the adapter and hook them up wirelessly.
Aug 25, 2012 | Toshiba Computers & Internet
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
How do i connect my acer aspire 5810T to my tv, thanks
I am assuming that you want to display your laptop on your TV. Since you did not post what TV you have, I am listing multiple ways to connect your laptop to your TV. Just pick the right type connection that works for both your laptop and TV, connect OUT of laptop to an INPUT on your TV. Set your TV to that input (mode) and if you see nothing on the TV, look at your laptop keyboard at the F keys (function keys) for the one with a double display image on it, pree the function button and the F key to set the laptop to external display.
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
If by chance you are attempting to hook up the TV to the laptop to capture video from the TV, you need to hook up your wire to the OUTPUT of the TV and you will need a capture card or hardware and software to do this. I hope this helps and good luck. Please vote appropriately and leave a comment.
Oct 29, 2009 | Acer Aspire AS5530-5824 Laptop
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
ASUS U52F-BBL9 Laptop Logo
200 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
