I need the drive gear for the non-direct drive cutter wheel. Where can I locate one?
    Genius:
  • 1,218 Answers
Contact the supplier...as you dont give make or model cant help any further.
Posted on Jun 20, 2011
Replacing the pinion gears in each wheel. Which way do the ratchet pawls go?
the pawls are positioned so that when the wheels rotate in a forward direction they lock up the pinion and drive the cutter blades ,
they release when the mower is pulled backwards
as for grease , if it had none then none is what is used
If it had grease then a water resistant bearing grease would be prefered
May 28, 2016 | Scotts 20" Classic Reel Mower
Viking 936 Machine is not cutting fabric, but continues to sew. What can cause this?
More than likely the cutter/knives need replacing or are not coming up all the way to catch the fabric. Put a piece of fabric on the plate just before the cutters and turn the hand wheel slowly. Are the cutters coming up above the fabric and moving to below the fabric to complete the cut? If not, open the front cover/door and turn the hand wheel watching the cutters' movements. You should see the gears that travel up and down. Many times this area becomes packed with lint/fabric and binds the movement. I usually take a large needle and dig out the lint/fabric or whatever else is stuck in that area. You'll be surprised how much you will remove from that area.
Jun 20, 2014 | Husqvarna Huskylock Computerized 936
Greetings, My car started showing some issues yesterday, it gives me a sign, 4low! don't know what means and it has started performing complitly different and slow, is not changing gears too!...
On any suv with 2 and 4 wheel drive options 4 low generally means that the transmission is in 4 wheel drive low gearing option so that the most possible torque is transferred to the wheels by way of what would be called a granny gear. What you will need to do is check your 4 wheel drive settings to see if the transmission has been put into this option which is either on a separate shift lever or a push button either on the shift handle or on the dash. Your owners manual should also direct you to where the selector is at.
May 29, 2011 | 2009 Lexus LX 570
Where is the camshaft located in a 2004 pt cruiser
The camshaft position sensor on an 04 pt is located on the right side of the engine, towards the top (looking at it from the front), directly in back behind the oil dipstick on a non-turbo
Jun 24, 2010 | 2004 Chrysler PT Cruiser
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
Where is the four wheel drive button located in the hummer?
On the dash directly in front of the right side of drivers seat is a trio of selector switches. The top switch is a constant amber light indicating all wheel drive if equiped, the switch below it is 4h, or four wheel high gears, this is only operational in trans selction mode of D, the switch on the bottom of the trio is 4L, which is only operational in 1st gear. There is also a switch for axle interlock, which gives the truck positive traction in 4 wheel only.
Feb 27, 2010 | 2003 Hummer H2
Fix the flexible drive shaft has a problem
The Metal Clamp referenced clamps directly on the end of the '2-Piece Gear Box Assembly'. The gear box assembly is an aluminum casting held together by 3 machine screws. The Metal Clamp does not actually lock the drive shaft housing into the gearbox assembly. The flexible drive shaft cable engages the engine output shaft, and the gear box assembly. This is a fixed length (non-adjustable) assembly.
First ensure that the drive shaft assembly is fully engaged at the quick connect fitting and that the "snap" is engaged. Then make sure the knob is fully tightened. The quick connect allows you to quickly switch between various attachments offered on this unit.
Now, based on your description, it sounds like the 'anti-rotation screw' 791-182519 has backed out or is gone. This will allow the entire cutting assembly (gearbox forward) to slip off of the drive shaft housing and disengage the flexible drive shaft. If your cutting assembly is attempting to rotate while in operation, or the drive is not engaged as you described.
Do not continue to operate the unit until you get this fixed as you could strip out the drive shaft end or cause other serious damage to the equipment or yourself.
If it is the anti-rotation screw, then make sure to push the drive shaft housing firmly into the gear box and ensure to align the holes in the drive shaft housing and the gear box. If the screw is lost, then find one similar sized, but be CERTAIN that it is not too long as it will actually engage the flexible drive shaft and prevent rotation, or cut the drive shaft.
Back to the clamp: If it is still wanting to move, then remove the lock nut and place slightly oversized washers on the bolt head and the lock nut. This will force more pressure (does not take much) on the clamp and will lock it down.
I just fixed mine today (071809) in fact and had to drill a new hole in the drive shaft housing as the original was completely wallowed out.
I hope this helps.
DROPNDEAL
Jul 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
The wheel furthest from the drive motor doesn't turn.
Most parts are available. But probably have to buy whole cutter asm.
Jun 17, 2009 | Fellowes DM8C Cross-Cut Shredder
1994 audi 100s transmission problem, cumputer, no reverse AUDI VW
Hi I also have an Audi Auto 2.8 non quottro had a simler problom and it turneed out to be one of the gear relays that are under the stering wheel on a left ****** that is.
Mar 11, 2009 | 1996 Audi A6
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
23 people viewed this question
jasbo
jasbo
