Question about Cobra 29 LTD CB Radio
Will not modulation - Cobra 29 LTD CB Radio
  • 391 Answers
Hi firstly this could be a number of faults ,are you getting tx power ,is it receiving ok ,when you press the ptt /mic/is the needle on the metre moving ,please check the wirering in the mic for short or bad solder joint iff all fails its more than likely your audio chip that has gone check with multimetre to source problem hope this helps you
Posted on Mar 18, 2011
Code U1016 2000 Grand Am GT
DTC U1001-U1254 Loss of Communications
Powertrain Control Module (PCM) U1016
Vehicle not starting an running ?
Do you know anything about GM class 2 serial data network .
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring (Node Alive messages). A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that module's Node Alive message. Each module on the class 2 serial data circuit which is powered and performing functions that require detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a learned identification number for 10 seconds, a DTC U1016
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that can not communicate.
Control Module
ID Number
016
Electronic Brake Control Module (EBCM)
040
Body Control Module (BCM)
064
Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Do you know how to do a loaded circuit test for the power an ground circuits for that module ?
The Trainer 61 DTC Diagnostics Pt1 How The ECM Thinks
ECM Inputs and Outputs Diagnosis
Feb 28, 2017 | Pontiac Grand Am Cars & Trucks
I have a 2003 bonniville sle i have a code U1040. Where is the EMCM AND PCM LOCATED
U1040
DTC U1001-U1254 IPC, PCM, SDM
040
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for 5 seconds, a DTC U1??? where ??? is equal to the 3-digit identification number is set.
Control Module
ID Number
016
040
Dash Integration Module (DIM)
064
HVAC Control Module or IPM
065
Rear Integration Module (RIM)
066
Inflatable Restraint Sensing and Diagnostic Module (SDM)
088
096
Head Up Display (HUD)
098
Radio
128
Remote Playback Device - CD Changer
130
Digital Radio Receiver (DRR)
137
Vehicle Communication Interface Module (VCIM)
151
Driver Door Module (DDM)
160
Front Passenger Door Module (FPDM)
161
Left Rear Door Module (LRDM)
162
Right Rear Door Module (RRDM)
163
Memory seat Module (MSM)
166
Driver Door Switch Assembly (DDSA)
170
Remote Control Door Lock Receiver (RCDLR)
176
Theft Deterrent Control Module
192
The electronic brake control module is communicating , no need to bother the PCM . The code was set in pcm because it lost communication with EBCM , PCM not the problem .
Left Front lower corner of the engine compartment, under the air cleaner housing .
Check power's an ground's . Will a scan tool talk to it ?
Oct 03, 2016 | Cars & Trucks
Were is the TDM located?
TDM ? explain what you think this is ? If you are referring to a module here is a list of the ones on your caddy.
The control modules on the class 2 data line can include the following modules:
The body control module (PZM)
The cellular telephone module (PHN)
The climate control panel (CCP)
The continuously variable road sensing suspension (CVRSS) module (RSS) (w/F45)
The electronic brake and traction control module (EBTCM) (ABS)
The heater and A/C programmer (HCM)
The inflatable restraint sensing and diagnostic module (SDM)
The instrument cluster (IPC)
The memory mirror module (MMM) (w/A45)
The memory seat module (MSM) (w/A45)
The powertrain control module (PCM)
The radio (IRC)
The radio interface module (RIM) (w/UQ4)
The remote function actuator (RFA) module
Dec 10, 2015 | 1999 Cadillac DeVille
Detailed instruction on replacing ford GEM
It's not that complicated , disconnect all the connectors ,unbolt the GEM from it's mounting bracket ,install in the reverse order . The only hard part is if it needs to be programmed . On your vehicle ford calls it a vehicle The vehicle security module controls the following systems:
  • perimeter alarm
  • remote keyless entry (and panic feature)
  • computer-operated locks
  • auto lamps
  1. NOTE: Prior to removal of the vehicle security module, it is necessary to upload module configuration information to a diagnostic tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Section 418-01 .
    Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the pushpin and the RH interior kick panel.
  1. Remove the glove compartment. For additional information, refer to Section 501-12 .
  1. Disconnect the three vehicle security module electrical connectors.
Configurable Modules The vehicle contains the following modules that are configurable:
  • vehicle security module
  • 4-wheel anti-lock brake/traction control (ABS/TC) module or stability assist module (if equipped)
  • electronic automatic temperature control (EATC) module
  • instrument cluster
  • powertrain control module (PCM)
  • driver seat module (DSM)
  • tire pressure monitor module
  • vehicle dynamics module
  • power liftgate module
  • temperature-controlled seat module
Nov 11, 2015 | 2003 Ford Expedition
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
Nov 26, 2014 | 2009 Volkswagen Tiguan
Error code 105
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Sep 26, 2013 | Fisher and Paykel Washing Machines
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
Control Module.
Phase 2 to 3
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Feb 21, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fix code 104
104. (01101000) See Fault Code 106
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hi, The following is the spec. What is the best graphics card upgrade options without upgrading PSU? Thanks. 1 03FCY Base,Mini Tower,Configure To Order,INSP 560 $358.67 1 07GHK...
HERE is the direct link from Dell that will tell you what graphic card will go into your system. Since there are many factors involving graphics card updates this is the best place to start.
Jan 06, 2011 | Dell Inspiron 560 PC Desktop
Cobra 29 LTD CB Radio Logo
145 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
