Question about Dell Dimension 4550 PC Desktop
My Dell Dimension 4550 starts up and after about 30 seconds shuts off. It does not matter if I boot in safe mode or normal and I have disconnected everything but the monitor, keyboard and mouse.
  • 38 Answers
If the computer shuts off completely like someone pulled the plug from the electrical outlet, it is probably your power supply. I would first check all the main cable connection from the power supply to motherboard. If the problem persists, swap out the power supply. Thanks.
Posted on Mar 18, 2011
Boot Dell Dimension computer Safe Mode
Immediately, start pressing the F8 key once a second until the Advanced Boot Menu appears. If the computer starts up into Windows, turn the computer off and try again. Press the Up Arrow or Down Arrow key to highlight Safe Mode with Networking, then press Enter
Jan 17, 2014 | Dell Dimension Computers & Internet
Dell 4700 power up to desk top then shuts down
check your cpu fan if still working. if it is working try to edit your bios to safe defaults and save it then boot up. also try to boot on safe mode if it is ok in safe mode then try system restore...if worst.. format your pc
Aug 10, 2012 | Dell Dimension 4700 PC Desktop
When i turn my computer on the dell loads up and when it goes to the black screen afterwards it restarts and keeps doing that/ i have dell dimension c521. help
have you added any ram recently or anything? i would suggest booting into safe mode press f8 after the bios and try and do a roll back and shut off any un needed programs via run-msconfig-start up. also DISCONNECT ANY USB DEVICES
Mar 14, 2011 | Dell Dimension C521 PC Desktop
I have a Kogi l4ax monitor that I am trying to hook up to a Dell Dimension 7000. The monitor works on my dell dimension 4550. When I start the computer it shows the windos Xp screen for 2 seconds then...
Are you able to boot in SAFE MODE? since your monitor works on one PC, but not another, it could be your screen resolution settings in the OS on the 7000 - safe mode loads only basic windows components - and you should be able to get to the desktop and reset the resolution down to a size that suits the monitor you are using. Alternately, if you are not comfortable with uninstall tools or don't want to waste a day going into safe mode all day long to fix something which may not need attention, if you have access to a spare monitor you can try it on the 7000 and see if you get the same message at normal startup - if you don't - you can lower the resolution a tad once you get to the desktop, shut down as usual, hook the I4ax back up, reboot and see if it works. Either of these suggestions will only cost you a bit of your time - zero money and should have no negative impact on your OS or any associated hardware. This is a simple DIY deal and worth a try at least.
Dec 18, 2017 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Computer turns off by itself
Depending on if you get any error messages at all.. Then do the following. If you get an error message, Post it back here for more specific directions on how to fix this issue.
First, remove all devices attached to the computer except the keyboard, mouse, and monitor.
Then.. Shut the computer down, start it, and press f8 to enter safe mode..
Does the computer randomly shut down in safe mode? If not then your issue is software, and can be fixed without replacing anything.
Aug 17, 2010 | Dell Dimension 4550 PC Desktop
I have an dell dimension e510 that boots to a black screen I have tried just about everything I can think of to fix it, I don't even see any way to boot to safe mode any ideas?
1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
4- Replace your battery.
5-Restart
Mar 02, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
Dell laptop runs in safe mode only
Try a system restore - boot to safe mode and restore it to an earlier working state.
Jan 02, 2010 | Dell Computers & Internet
Dell Dimension 4550 wont' boot-gets to windows logo and reboots-running XP Home Edition
Try booting in safe mode, if it fails install new Operating system.
Oct 28, 2009 | Computers & Internet
Dell Dimension 4550 PC Desktop Logo
69 people viewed this question
Alun Cox
