Question about Rotary Agl Lasers Selfleveling Laser Level System new
I have an AGL LT200 that will not spin once it has self-leveled. It just continues to blink as it does while it levels itself. I can also hear it making very slight movements internally as though it is still trying to level itself. Battery is charged. Unit is almost 5 years old but with very little use. Sometimes if I wait long enough (10-15 minutes) it then starts to spin.
Makes clicking noise spin cycle
it may be any part of the balance mechanism under the machine..remember if you did not balance (level) it prior to installing, it has to self level on its own..this usually calls for some noise in the linkages when spinning..
Mar 04, 2014 | Maytag MAT15MNAWW Top Load Washer
Laser is level but out of level light blinks and will not spin
Your compensator and leveling vial are no longer aligned. Use your foot screws to find a place where the laser spins, then use the 3 hex head screws on the vial, to adjust it to read level.
Dec 23, 2012 | Spectra Precision Laser LL500 Exterior...
Why is the Green light not blinking?
Do a peg test, if the unit is leveling and accurate, then it's just the green diode has malfunctioned, dont worry about it, it happens.
If the peg test fails, then either the keypad board has failed, or a motor may be jammed. Or possibly the laydown switch has is stuck, and the laser things it's perminatly in vertical mode, and wont level. Take it to a laser/survey shop as the front label will have to be replaced just to open it, to diagnose.
Apr 01, 2012 | Spectra Precision Laser LL400 10 Automatic...
Whirlpool WW1206
WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
PLEASE KINDLY ADVISE
Jan 17, 2011 | Whirlpool Washing Machines
The mowing deck on craftmans lt200 is leaning to one side. this causes an uneven cut
I think one of the hangers has become disconnected. There should be a leveling procedure for this in your owners manual. If you dont have that manual ... you may find the leveling procedure at the Sears web site. Leveling procedure is pretty standard ... the basic idea is get on a level surface --- your garage --- measure from the deck to the floor on 4 corners ... make adjustments as required front to back and then side to side. Once you are on the floor ... you will see what to do.
May 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't keep washer level
as far as leveling goes once leveling legs have been set,you can lock them in place by turning the nut on leg itself counter clockwise until its secure to top of leg,however if the unit is shaking during spin cycle and is located in upper floor laundry setting,chances are the floor is weak,and cannot withstand downward force generated during final spin...add an absorption pad under unit to assist/alleive the issue
Mar 10, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My comercial washer does not stay level when spinnig,seems like the self leveling device is not staying put ,i can lift it up to level it but it still wants to dance around.
YOUR REAR LEVELING MECHANISM IS SELF LEVELING FROM SIDE TO SIDE YOUR FRONT FEET ARE INDIVIDUAL MAKE SURE THE REAR OPERATES PROPERLY AND RELEVEL THE MACHINE IN BOTH DIRCTIONS. EACH TIME YOU MAKE AN ADJUSTMENT TO THE FRONT FEET WETHER IT BE THE RIGHT OR THE LEFT RE-RAISE THE REAR SO THAT THE REAR ADJUSTMENT WILL AUTOMATICALLY SET ITSELF TO WHAT YOU HAVE CHANGED ON THE FRONT FEET. YOU MAY HAVE TO DO THIS REPEATEDLY TO GET THE BEST POSSIBLE LEVELNESS IN BOTH DIRECTIONS. ONCE YOU ARE SATISFIED THE FRONT FEET SHOULD HAVE A SET NUT RUN THIS NUT UP TIGHT TO THE BASE OF THE WASHER.
Apr 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Rotary Agl Lasers Selfleveling  Laser Level System new Logo
26 people viewed this question
Top Rotary Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Rotary Measuring Tool and Sensor Expert? Answer questions, earn points and help others
