Question about Sony Cyber-shot DSC-W170 Digital Camera
When I turn the camera one of the little doors that is suppose to open to show lens does not open completely. I have to manually push it up. Can this be fixed?
  • Sony Master
  • 6,771 Answers
Yes! it can be fixed, but to fix it correctly it will need to go to a camera technician, he must dismantle the lens housing and clean out the dirt and grime that has built up. The job will be on the pricey side, probably would be wise to get an estimate before you commit.
Posted on Mar 18, 2011
My Canon PowerShot SD1400 IS is completely dead
check the battery door switch - may sure the little flippy arem is not broken, or has been pushed out of the way so it is not operated by the battery door
May 31, 2012 | Canon PowerShot SD1400 IS / Digital IXUS...
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
When turned on screen reads "lens error" and the camera struggles to open the lens. It won't open the screen says error and only way to turn off camera is to pull the battery out.
does the lens seem stuck, does it not extend or retract properly? Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 03, 2010 | Nikon Coolpix S210 Digital Camera
Lens error . dropped camara and lens opened and now, when i turn on the camara, lens is open and screen says lens error
Apr 26, 2010 | Casio Exilim EX-Z750 Digital Camera
Describe your canon rebel hinge door error 99 Problem I get error 99 every time I try to shoot. Although, if I turn on the camera and open the door and close it while the camera is on I can shoot. So,...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Jan 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens error, restart camera
Dec 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Shutter doors out of alignment/won't open
Sounds like you will need to replace the shutter doors. Go to www.canon.com for a repair service form.
Mar 06, 2007 | Canon PowerShot A520 Digital Camera
No Image on display screen
Does the play back show any of the pictures you have taken before? are you sure the little lens cover is opening? there is a shield that closes down to keep the lens protected from debris and finger prints. Sometimes they can get jammed and not open. Tap on the front of the lens see if it opens. Switch it to auto mode if its not in auto mode.
Apr 04, 2006 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
