Question about Sony 4GB Memory Stick PRO Duo Memory Card
My sony memory stick pro duo is write protected
    Problem Solver:
  • 15 Answers
Knjk
Posted on Sep 03, 2013
  • john richards Sep 03, 2013
    Hook the sony pro duo up to a computer using usb. Now click Start Menu, click Computer, click Removable Disk(the one the duo is on), click Avchd, click Stream.
    Now you should see all the recorded files (they have the small movie icons).
    RIGHT Click on the first file, go down and select Properties at the bottom. In Properties box, UNselect Read-only.
    A pop-up will ask if you want to change all the files, press YES.
    Now all files can be deleted, moved, written and formatted.
    Problem Solver:
  • 13 Answers
There should be a lock switch on the card, most likely on the left side. Slide the switch into the opposite position and see if this fixes the problem. If not, try formatting the card from your camera and then attempt to load it on to your computer.
Posted on Mar 18, 2011
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
How to protect pro duo card from unauthorised viewing
you enter card into computer and and going card properties,there having security system.
Mar 24, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
Will a memory stick pro duo fit a sony cypershot dscs90?
General Specifications & Compatibilitie:
Recording Media : 32MB1 internal Flash Memory, Memory Stick® Media, Memory Stick PRO™ Media, Memory Stick Duo™ Media (with adaptor), Memory Stick PRO Duo™ Media (with adaptor)
Hope this helps.
Jul 01, 2011 | Sony Cyber-Shot DSC-S90 Digital Camera
My laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Mar 14, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory Stick PRO Duo is write protected
I had this problem and figured out a easy fix.
1. Take out memory stick from psp
2. Plug in usb to psp and start usb connection
3. Psp will recongnize there is no memory stick inserted
4. Now insert your memory stick and your good to go
For some reason you might have to repeat these steps everytime you want to access your memory stick.
Hope This Helps
Dec 23, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony Mavica MVC-FD2000 can't read memory stick...
THE CARD PROBLBLY HAS NOT BEEN FORMATTED...ARE YOU SURE IT IS A MEMORY STICK PRO "DUO" THERE ARE DIFFERNT KINDS OF MEMORY STICKS (PRO DUO, PRO, QUAL, ETC.)
Feb 21, 2008 | Sony Mavica MVC-FD100 Digital Camera
Sony 4GB Memory Stick PRO Duo Memory Card Logo
221 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
