Question about Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White
Fridge and freezer not getting cold although fan is on and it sounds like the compressor is on. But has now stopped running so I unplugged. Is the compressor gone? This fridge is only 8 years old.
  • Maytag Master
  • 4,654 Answers
Most times the compressor start relay and run/start capacitor may be defective. If the fans run yet compressor gets very hot on top it may be trying to start and cannot because those mentioned components need replaced. Pull away from the wall, unplug and lets remove the lower cover that hides the compressor. If compressor is hot it just may be short cycling because it need these components=> MTB1954ARW Compressor Components
Finding the correct model number for yours will be important in order to get the right parts. On side by sides and top mounts should be able to find the correct numbers here=>
Top Freezer Side-By-Side For user manuals and literature click logo=> fridge and freezer not getting - sea_breeze_117.jpg Product made for outside the US=> HERE Find model number's HERE If you feel like you need to test compressor click here=> Appliance 911 Sea Breeze Scroll to near bottom of page and read how to test a compressor. In most cases a new start relay and sometimes a hard start will give you fridge a few more years, Have questions? Let me know, Thanks, Sea Breeze
Posted on Mar 18, 2011
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
There is no cooloing effect
the coolling in a refrigerator occurs when the compressor forces freon thru the system and the expansion of gas in the coils of the freezer takes heat away thus cooling the fridge. if no cooling is happening then the compressor is not running, the freon is to low on the charge, or the small "cap" line from the compressor to the cooling coils is blocked. Unfortunately the compressor is the most expensive part of the refrigerator and if it has stopped this can be a expensive problem. there is a few other things that can make the compressor stop. there is an overheat protection device on the side of the compressor that once in a while opens up thus no electrical power to the compressor and no cooling. the other part that can fail is the cold control thermastat. if this opens up the fridge can't start the compressor because the open condition of the cold control never "calls for cold". the other simple thing that can stop the cooling is a totally frosted up coil condition. the air can't circulate around the coils so no cold gets to the inside of the fridge. simple test step one unplug the fridge for 10 minutes then plug back in. Do you hear the motor in the bottom run? If it runs wait ten more minutes and put your hand into the freezer compartment. Do the sides feel cold? if the motor (compressor) in the bottom runs but freezer doesn't get cold then the system is defective and there will be no easy fix. If the freezer does show cold then the problem could be with the "evaporator" fan that circulates cold. this is an inexpensive part and can be replaced at a reasonable cost.
Apr 22, 2011 | Whirlpool Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer and fridge not cold
Sounds like you have a stuck compressor. The buzz is the compressor trying to run but cannot.
A refrigeration mechanic with an hermetic compressor tester can reverse operate the compressor to get it unstuck
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Maytag 18.9 Cu. Ft. Top-Mount Refrigerator - White Logo
379 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
