Question about Canon LBP 1120 Laser Printer
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet is halfway in the printer. As a result it causes a paper jam.
    Master:
  • 325 Answers
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Posted on Mar 18, 2011
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
Canon LBP 5050N Printer keeps coming up with paper jam. Have turned off, then turned on. Still did not fix. Can you help?
My LBP 5050N would print one page normally then stop with the next sheet just starting to feed (i.e. just touching the first feed wheel). When I took the paper tray out, there was one sheet left behind and I could pull that out easily without it tearing. It was gripped lightly at the beginning of the feed path.
Starting the printer again gave me another copy of the already-printed sheet (I guess that's Windows getting an error message from the printer and treating it as not having printed the first sheet).
As it will always print one page properly before jamming on the next one, the problem was obviously not a small piece of paper stuck somewhere.
I cleaned the rubber wheels with Isopropyl Alcohol as best I could, but they were not obviously dirty or slick/hardened with age. The result was the same.
Then I noticed that the two blue paper grips on each side of the tray showed a small gap of 1 or 2mm. I pushed them in to tighten them gently against the paper and the problem was solved.
I've been searching in many places for an answer to the 'frequent paper jam problem' and not seen this mentioned, so thought it would be useful to have it on record here.
Yeah, I was mentally challenged - I focused on the wrong thing from the beginning.
Feb 18, 2013 | Canon LBP5050N A4 Colour Laser Printer...
Why is my LBP 1120 feeding multiple papers?
It is feeding multiple sheets because the seperation pad is worn and needs to be replaced.
Feb 14, 2011 | Canon LBP 1120 Laser Printer
It grabs several sheets of paper at one time
This is most likely a paper problem, the paper is basically sticking to the next sheet, Ensure the paper is stored in a cool dry place helps, dont load the paper with more than what you need for a couple of days and when loading the paper flick the pages to allow air between the pages
If this dosnt work try a different brand of paper
Sep 09, 2009 | Lexmark Optra E310 Laser Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Printer keeps jamming paper
without some information about the kind of printer and the weight/thickness of the paper, try to supply more information in a comment if you can, this is a generic answer.
many printers have a paper thickness adjustment that helps ensure that only one sheet is picked up at a time, and that the sheet feeds accurately,
if two or more sheets are picked up there are jams as multiple sheets do not feed well, and may not even get out of the paper tray. If the printer is set for a thicker paper, the lead edge of thinner sheets may miss its aimed path and wrap around guides or rollers, jamming.
The makers web page, or the user guide if you still have it, often have FAQ on paper jams,
Jul 02, 2008 | Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon laser shot lbp-1120
Needs new seperation pad, they go hard and shinny and no longer perform there duty
Dec 04, 2007 | Canon LBP 1120 Laser Printer
Canon LBP 1120 Laser Printer Logo
588 people viewed this question
old marine
old marine
