Question about Acer Aspire 5630 Notebook
Keyboard problem hi this happpened yesterday evening, if I press the following characters get this response, am having to use online key board to demonstrate this type 4 i get 45 type 5 i get 45 type 6 i get 67 type 7 i get 67 type the letter p and i get this character p[ p[lease help[ it really annoying thanks tigerwhite
  • 4 more comments
  • buriningtige Aug 02, 2008
    thank you, so you mean uninstall the keyboard device reboot, can you list the procedure here as unsure how to do this.
    xp p[rofessional 200-2
    i ran a system restore number of times which imp[roved this but these characters remaining still remain when typ[ing on keyboard
    thanks,again, so which device to select and remove as only offering add device not remove on control p[anel or add/remove window comp[onents.
    no joy, was wondering if can download new keyboard
    driver and install if will solve as do not wish to do system reloads,
    thanks
  • Anonymous Mar 12, 2014
    When typing on my C312 Advent wireless keyboard I find that some of the characters have not been added onto the text document. This is most annoying as it is usually the 'i' that is missing, more so when used as a capital. Spell-checker cannot detect misspelling of in when the 'i' is missing.
Thanks, will try and see if that works and let you know
Posted on Aug 04, 2008
  • 476 Answers
Try to uninstall the device and reboot
the system should auto recognise and install on start up
Try that and let me know the out come thanks
Posted on Aug 02, 2008
  • 6 more comments
  • Verne Koti Aug 02, 2008
    what OS are you running
    ok
    Go to START
    Then CONTROL PANEL
    ADD/REMOVE
    Select device and REMOVE
    REBOOT
    Restart,
    On restart the system should auto recognise and install the correct drivers and you should be good to go,
    Reboot again once device is working to your save your settings
    Dont forget SP2 updates for functionallity
    sorry try this instead
    START
    Right click on MY COMPUTER
    PROPERTIES
    HARDWARE
    DEVICE MANAGER
    KEYBOARD right click
    UNINSTALL
    REBOOT
    RESTART
    Try keyboard now
    If problem persists it ....
    could be time to format this computer and reload a fresh system again
  • Verne Koti Aug 03, 2008
    I found your manual,
    http://csd.acer.com.tw/acer/URMUL1.NSF/1...
    and I found the acer download site too
    good luck with the mission
    Please let me know the out come thanks
    sorry the acer download site is
    http://www.acer.com.ph/spareparts.php
    Hope this helps ,Let me know thanks
    I think I know what your problem is .....
    It just dawned on me.......lol
    This machine was designed for VISTA not XP
    Check the manual out for comparisons
    Check page 22 of the manual.
    If XP was loaded on to this machine then the install may still be missing components the machine will need to function correctly but if its worked before then ,the installer may have to reinstall the system again to bring back to factory default settings again.
    I must appologise for not recognising this earlier as we could have avoided a lot of down time from the start just recongnising the correct symptoms,
    I hope I have given you the help you were looking for,
    Please rate me accordingly thanks ....
    I have based my findings on the model Acer 5630 posted as your header,
    thanks Misterdj
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How do i change the business name, address and abn on the receipts for a Samsung ER-650
    Turn key to "PGM"
    Press "7"
    From the
    LOGO DESC. PROGRAM screen, press "0" to display the PREAMBLE screen:
    Using the alpha numeric keyboard overlay, type the first line of the message.
    Each line (6 allowed) can be up to 32 characters, although only the last 19 characters you have entered will display. If you make a mistake, press the "BACKSPACE" key to erase the previous character. After you have completed typing the first line, press "ENTER"
    to accept the new line and advance to the second line, or press
    "ESC"
    to return to the LOGO DESC. PROGRAM screen without making any changes.
    Thank You
    Team
    ACP ONLINE
    Jan 29, 2015 | Samsung SAM4s ER-650 Cash Register
    S60e 3etters 6n 0y 2eyb6ard res43t 5n the wr6ng character. Th5s -r6b3e0 sh6wed 4- wee2s after -4rchase. n5t5a33y 5t was w6r25ng f5ne
    Hi wa33ban2hart
    Question: "Some letters on my keyboard result in the wrong character. This problem showed up weeks after purchase. Initially it was working fine".
    You've done unbelievably well to type an error-free, letter-perfect question, despite the character confusion.
    This is a very strange problem to have on a desktop keyboard (Dynex Keyboard and Mouse), since the way to achieve the above sentence as you have written it, is to use the Fn and NumLk keys, on a laptop keyboard, to enable buttons with multiple functions to print their alternative characters designated to them.
    Desktop keyboards do not usually have Fn keys and the NumLk key on a desktop keyboard locks and unlocks the Number Pad on the right of the keyboard, which usually has no alternative letter values on its keys.
    Solution: Press and hold the Fn (Function) key on your keyboard > press the NumLk (Number Lock) key (usually F10, F11 or F12) > release both keys > test keys J, K, L, U, I, O etc. again.
    That should resolve your problem.
    I hope this helps.
    If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
    This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
    If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
    Thanks for using FixYa
    Sep 11, 2011 | Dynex Keyboard and Mouse
    I have ASUS EEEPC 1005 HA Yesterday the character that comes after "A" stopped working . I have tried to open it, tried to get rid of the dust even put some WD 40 on the key too , its not jammed,...
    Carefully pry up they A key.
    You will see a little rubber thingy under the key, pop it up and you will see a little circuit board under where the A key was located.
    Very gently clean SOME of the gunk off the circuit board contact, while keeping the circuit board undamaged (I usually find a nice new rubber pencil eraser works fine for this task).
    Then gently wipe the bottom of the little rubber thingy off with a piece of printer paper (you are going for keeping the black on the rubber thingy but the sticky gunk off)
    Then replace the rubber thingy and the A key and give it a go,
    If that does not help then yes you will need a new keyboard. You can also disconnect the ribbon cable that goes to the keyboard and connect an external usb keyboard and try that to get you by.
    Sep 02, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
    My keyboard or key pad will not work
    Sounds like you have sticky keys enabled
    Press and hold down the keys for about 5-10 seconds until you see a character or some response on your screen.
    When you get into Windows follow these steps:
    Step 1. Click Start - Control Panel
    Step 2. make sure you are in Classic View, Go to Accessibility Options
    Step 3. Click on the Keyboard tab and uncheck Enable Sticky Keys
    Step 4. Click Ok, then Ok and exit
    Apr 21, 2010 | Acer (90.45207.011) Keyboard
    ACER ASPIRE 4520 keyboard problem
    In laptops with a small screen (14,15" ) the keyboard is accordingly smaller than for desktops, and there is no numeric keypads, or arrow pad. So the keys 7,8,9 0, U,I,O,P,J,K,L ,comma, dot, / have a triple function: the primary function, the shifted function, and a third accessed by an FN-Fx key combination. The actual key combination may depend on manufacturer. If that key combination has been activated, the foregoing keys perfom the third function they were designed for..
    Read your laptop manual to find out how the Fn- function key works and deactivate the Fn-Fx combination responsible for your keyboard behavior..(this article was posted by k24674)..
    or else u r keyboard is likely to b defective or ur ram or the system board..
    lightly strike/tap the keypad using ur hand..
    if u r a professional, open the keyboard..deep clean all the carbon contacts beneath the keys using Iso-Propyl alcohol..put/stick 'Carbon-Dots' (available in cheap level spare market) as n where necessary..
    hope it'll work..
    always better to seek professional supervision esp of ur system admin/vendor....
    Nov 23, 2009 | Acer Aspire 4520-5582 Notebook
    FUNCTION KEYS & OTHER RIGHT HAND SIDE KEYS
    That means that you turned on the numlock on the laptop keyboard, On an acer if im not mistaken you have to press one of the function keys to deactivate it. Look for the icon with NUM on it and press it. if that does not work you may have to press FN then that icon.
    Sep 20, 2008 | Acer 91.63X07.001 Keyboard
    Toshiba tecra s2 keyboard starts skipping typed characters and stalling
    there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
    pls remove the key board cap carefully and clean
    Apr 29, 2017 | Toshiba Tecra S2 Notebook
    Logitech mx3000 keyboard
    Normal 0 Press the Receiver button (and the lights will start flashing.
    Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
    Feb 13, 2008 | Logitech MX3000 USB PS/2 Wireless...
    Acer Aspire 5630 Notebook Logo
    252 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
