Question about Garmin nuvi 1350 Car GPS Receiver
My Garmin 1350 will not bring up the GPS program. When I turn it on, it goes to the screen that show GARMIN and appears to lock up. It never gives me the option to enter a destination.
  • eggersjp Mar 19, 2011
    None of the suggested options were successful, therefore, I am just trashing this GPS and will buy another one, NOT GARMIN.
    Genius:
  • 1,043 Answers
If you haven't already done so, the first thing you can try is to reset the unit. You do this by pressing and holding the Power button. The unit should reboot itself. If your unit still locks up, you will have to re-install the unit software. This can be done by going to the Garmin website, and then setting the country location to the appropriate area. Then click on the Support link at the top of the page. At the bottom of the page that comes up will be a heading for Additional Software. Clicking on this link will then take you to the area that will have links to your unit's software, or it's basic operating system.
The other way to achieve this is to use the USB cable that came with your unit. Connect the small end to your GPS, and the larger end to a USB port on your computer. Go to the following website:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
If you haven't already done so you will have to register yourself, as well as your GPS. There is a program called the Web Updater. Once you have been registered the system will check to see if this program is already on your computer. If it isn't, the webpage will have you install it. Once it is installed, it will communicate with your GPS and then tell you if there is any software that you need to update on your GPS. Quite often the system will detect that you have a problem with your unit software and will automatically repair it for you.
If it doesn't, you can download the unit software to your computer. Using whatever file manager you normally use with your computer (Windows Explorer, Total Commander, etc), unpack the unit software to a handy location. Your file manager will show your Garmin GPS as another removable drive in your system. Move or Copy the unit software over to your GPS. The system will ask if you want to Overwrite the files that are already on your GPS. Answer Yes to every query, or Yes To All. Once the Overwrite is complete go back to the Garmin website and run one more check to make sure that you have all of the latest versions of your Unit Software.
IF you run through the entire operation, and you still have lockups, or you are unable to complete the update, you probably have a hardware issue. If you still have any warranty left on your GPS take it to your Garmin repair center and let them diagnose and repair the issue. If you are out of warranty then you should get a quote on the repair. It may cost less to buy a new unit than to repair your old one.
Posted on Mar 18, 2011
I plugged in my garmin nevi 1350 into my computer for updates, and it's not showing up on the screen (MAC). The update program can't find the device on the screen. What am I doing wrong? marilyn
Perhaps nothing.
Does the GPS turn on and go into usb mode when plugged into your MAC? If not, it is probably a driver issue if the GPS works normally in your vehicle. You might try the Communicator Plugin for MAC. https://www8.garmin.com/support/download_details.jsp?id=3739
Feb 19, 2017 | Garmin Nuvi 1350/1350T 1300 1390 3790T...
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Favorites Backup
Garmin Nuvi 1350 Hard Reset
on May 15, 2010 | GPS
Tip
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
Nov 06, 2013 | Garmin nuvi 1350 Car GPS Receiver
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 Car GPS Receiver Logo
1,725 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
