Question about Dishwashers
I just bought a replacement float switch, their is a blue and brown wire. I cant remember which one goes where?
  • Dishwashers Master
  • 43,501 Answers
It does not matter...they are interchangeable..
heatman101
Posted on Mar 18, 2011
Hoover HWD-20 We want to replace the switch but forgot where to fit the two blue and brown wires in
blue from mains should (connect on the switch ) go to blue wire and brown to brown OVER the switch The switch shouild not connect brown to blue on the powercable . use even a multimeter or
You should know ofcourse where the right points are sometimes there is a little connection diagram on the switch self but not large enough to see or letters on the connectionpoints L and N phase (brown wire) and zero (blue wire) from the motor and electronic assembly if the switch have only 2 contacts then connect blue wire direct to blue wire and brown to brown OVER the switch.
Hoover HWD020 Instructions Product View And Parts Blow Function
Nov 28, 2017 | Cars & Trucks
Rotary switch black red and blue wires replacing old switch with black, red and brown. I can't remember the wire sequence. What's hot what's not. For a old pole lamp with 3 bulbs
Without seeing the switch it is difficult to say for sure.
My best guess would be black is the hot lead and red and brown/ blue are the switch leads. This is a best guess only.
Hope this helps.
Bob
Feb 09, 2017 | Rotary Electrical Supplies
I have removed the Dastek Unichip B from my corsa an now wants to reinstall it,but Icant remember what wire go where?
why not ask UNICHIP.
it is their piggyback. ask them. it a custom hack for a car.
how it fits your unstated car and engine, is not knowable.
May 23, 2014 | Opel Corsa Cars & Trucks
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
Rca d52w19 forgot where brown and blue wires plug in!!!! help!!!
if it has a "dummy" pin then it can only go one way
if its brown/blue its normally the mains input so it will work or not
try taking off the connector and see if anything has snapped off , should be easy to tell if you got it right.
Aug 18, 2009 | RCA D52W19 52" Rear Projection Television
Bmw e46 electric wing mirror wiring diagram
your mirror control switch has 9 wires.,your drivers door mirror has 5 wires color coded .from your mirror control switch to your drivers siide mirror / 0.5 black .0.5 brown. 0.5 brown. 0.5 black. 0.5 black.
your passenger mirror wires are 0.5 blue/black .0.5 blue/grey. 0.5 blue/white. the passenger mirror has a ground cable 0.5 brown.
the passenger mirror wire 0.5 green/white connects to a 5amp fuse/F25 onto F31 5amp to a wire 0.75 green/yellow.back to the mirror control switch.
Jan 20, 2009 | 1999 BMW 318 ti
Switch connections
I have a Jenn-air, and the switch for blower and light is on top, front. the switch has 4 connections on the bottom, and viewed from the bottom, the white wire goes at 12 o'clock, the red and brown wires are in the top left corner (paired with the white one) and the black wire is at 6 o'clock, and the blue (double wires) goes in the lower right corner (paired with the black one). If you have a continuity tester, the switch is a dpdt, and white is connected to red-brown (double wires) OR black is connected to blue-blue( double wire).
Hope this helps.
Aug 26, 2008 | Kitchen Ranges
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
