Question about Canon NP 7130 Black and White Copier
Someone attempted to change the toner cartridge and now it appears a bracket securing the cartridge holder in place is broken. The cartridge holder hangs down on the left and therefore the copier will not close easily. If forced closed, it still does not print. Is this repairable or should the copier be put in the dumpster? It was donated to my classroom and no longer has a service contract. Thank you.
  • Canon Expert
  • 270 Answers
Sounds as if the pressure spring that keeps the developer unit close to the drum is broken. Not worth fixing will cost around $250.
Posted on Jun 21, 2011
  • lairdog Jul 20, 2011
    I fix those for around 60.00.
My Phaser 6125 printer has broken part in the cartridge holder and now the color ink cartridge cannot be taken out of the printer, can I fix this problem (DIY)
The toner holders are each sold separately, the part numbers are 604k44920, 604k44930, 604k44940, and 604k44950.
http://www.iteminconline.com/604k44920_604k44920-xerox-6125-holder-k.htm
Jan 02, 2016 | Xerox Phaser 6125 Laser Printer
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
Hi- I have an MF8170c. The green "recv'd in memory" indicator is lit and I know there are documents que'ed that are waiting to print. I changed a printer cartridge that was I was being...
Replacing the Toner Cartridges
If printout becomes faint or inconsistent, the reason may be that the lifetime of the toner cartridge has been reached even when a message does not appear. Do not continue to use the toner cartridge when there is a deterioration in the print quality.
The lifetime of toner cartridges for this machine is indicated as follows. The number of pages is based on printing a typical document (with a printing ratio of approximately 5 % and print density set to default).
- Black (EP-87) Toner Cartridge Black): Approx. 5,000 pages for printing paper in size of A4 or Letter.
- Yellow, magenta, cyan (EP-87 Toner Cartridge Yellow, EP-87 Toner Cartridge Magenta, EP-87 Toner Cartridge Cyan): Approx. 4,000 pages of printing paper in size of A4 or Letter.
When [PREPARE NEW* CART] and then [REPLACE* CARTRIDGE] appears in the LCD, replace the toner cartridge of the indicated color with a new toner cartridge.
* Indicates either "C", "M", "Y", or "K"
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite resulting in burns or a fire.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Do not use warm water as this may set the toner permanently, and you may not be able to remove the toner stains.
Use only toner cartridges intended for use with this machine.
Press .
Press or to select [MAINTENANCE], then press .
Press or to select [CHANGE CARTRIDGE], then press .
Press or to select the cartridge to be replaced, then press .
You can select from the following:
-[BLACK]
-[CYAN]
-[MAGENTA]
-[YELLOW]
-[ALL COLORS]
Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
Make sure that the toner cartridge you want to replace is at the position for replacing.
If the spent toner cartridge is not in the replacement position, close the cover, then open it again when the sound of machine stops. Repeat this process until the cartridge you want to replace is in the correct position.
Remove the toner cartridge from the machine.
Hold the grip on the toner cartridge and lift it straight up.
Confirm the color of the label on the toner cartridge holder, then take out a toner cartridge of the same color from the protective bag.
Open the protective bag with scissors, so as not to damage the cartridge.
Keep the protective bag in which the cartridge came in. It may be required when taking out the toner cartridge for machine maintenance.
Be careful not to hold or touch the prohibited portions such as the sensor or electrical contacts. It may result in damage to the machine.
Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
If toner is not distributed evenly, it may result in a deterioration of the print quality. Be sure to carry out this procedure properly.
Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
It may be a little snug, but it will pull off.
Do not touch or hold the developing roller. The image quality may deteriorate if you do. Do not apply shock to the toner cartridge memory or bring it near magnetic waves as this may result in damage to the machine.
Keep the protective cover with which the cartridge from removed. It may be required when taking out the toner cartridge for machine maintenance.
Place the toner cartridge on a flat surface, then pull out the sealing tape (Approx. 45 cm (17.72") in length) while supporting the toner cartridge.
Hold the tab on the sealing tape and pull it straight out.
If the sealing tape is pulled out forcefully or stopped at midpoint, toner may spill. If toner gets into your eyes or mouth, wash it away immediately and consult a physician.
Do not pull the sealing tape diagonally, upwards, or downwards. If the tape is severed, it may become difficult to pull it out completely.
Pull out the sealing tape completely from the toner cartridge. If the sealing tape remains in the toner cartridge, it may result in a deterioration in print quality.
Dispose of the sealing tape according to local regulations.
Hold the grip on the toner cartridge and install it in the machine.
Position the triangular mark on the toner cartridge with the triangular mark on the machine and instlal the toner cartridge.
When the toner cartridge is installed properly, the label on the cartridge and on the toner cartridge holder will be aligned as shown in the figure.
Close the cartridge cover and lower the scanning platform.
The toner cartridge holder will rotate automatically.
Aug 31, 2011 | Canon imageCLASS MF8170C All-In-One Laser...
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Jul 16, 2010 | Dell 3010cn Laser Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Inatallation of a printer
Hello , I believe I can help you out.
First here is a bit about your machines toner maintenance.
Second will be how to change the cartridge.
Remember if I was of assistance please be kind and leave a kind quick testimonial and good rating.
Maintaining the toner cartridge
Toner cartridge storage
Toner cartridges contain components that are sensitive to
light, temperature, and humidity. Samsung suggests users
follow the recommendations to ensure the optimum
performance, highest quality, and longest life from your
new Samsung toner cartridge.
Store this cartridge in the same environment as the printer
it will be used in; this should be in controlled office
temperature and humidity conditions. The toner cartridge
should remain in its original, unopened package until
installation – If original packaging is not available, cover
the top opening of the cartridge with paper and store in a
dark cabinet.
Opening the cartridge package prior to use dramatically
shortens its useful shelf and operating life. Do not store on
the floor. If the toner cartridge is removed from the printer,
always store the cartridge:
• Inside the protective bag from the original package
• Correct side up in a horizontal position (not standing on
end)
• Do not store consumables in;
- Temperature greater than 40°C (104°F).
- Humidity range less than 20% and not greater than
80%.
- An environment with extreme changes in humidity or
temperature.
- Direct sunlight or room light.
- Dusty places.
- A car for a long period of time.
- An environment where corrosive gases are present.
• An environment with salty air.
Handling instructions
• Do not touch the surface of the photosensitive drum in
the cartridge.
• Do not expose the cartridge to unnecessary vibrations
or shock.
• Never manually rotate the drum, especially in the
reverse direction; this can cause internal damage and
toner spillage.
Use of non-Samsung and refilled toner
cartridge
Samsung Electronics does not recommend or approve the
use of non-Samsung brand toner cartridges in your printer
including generic, store brand, refilled, or remanufactured
toner cartridges.
CAUTION: Samsung’s printer warranty does not cover damage to
the machine caused by the use of a refilled, remanufactured, or
non-Samsung brand toner cartridge.
Estimated cartridge life
Estimated cartridge life (the life of the toner cartridge yield)
depends on the amount of toner that print jobs require. The
actual print-out number may vary depending on the print
density of the pages you print on, operating environment,
printing interval, media type, and/or media size. For
example, if you print a lot of graphics, the consumption of
the toner is high and you may need to change the cartridge
more often.
Redistributing the toner cartridge
When the toner cartridge is near the end of its life:
• White streaks or light printing occurs.
• The warning message, Toner Low displays on the control
panel.
• The Smart Panel program window appears on the computer
telling you that the toner cartridge is low on toner.
• The Status LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the toner cartridge. In
some cases, white streaks or light printing will still occur even
after you have redistributed the toner.
1 Open the front cover.
2 Pull the toner cartridge out.
3 Thoroughly roll the toner cartridge 5 or 6 times to
distribute the toner evenly inside the toner cartridge.
NOTE: If toner gets on your clothing, wipe it off with a dry
cloth and wash clothing in cold water. Hot water sets toner into
fabric
Changing cartridge:
_______________________________________________________
CAUTION: Do not touch the green underside of the toner
cartridge. Use the handle on the toner cartridge to avoid
touching this area.
4 Hold the toner cartridge by the handle and slowly insert
the toner cartridge into the opening in the machine.
5 Tabs on the sides of the toner cartridge and corresponding
grooves within the machine will guide the toner cartridge
into the correct position until it locks into place completely.
6 Close the front cover. Make sure that the cover is securely
closed.
Replacing the toner cartridge
When the toner cartridge is completely empty:
• The printer stops printing.
telling you that the toner cartridge is empty.
• The Status LED lights red.
At this stage, the toner cartridge needs to be replaced. For
order information for toner cartridges, see page 7.1.
1 Pull the toner cartridge out.
2 Remove the new toner cartridge from its bag.
3 Roll the toner cartridge 5 or 6 items to distribute the toner
Thoroughly rolling the toner cartridge will assure
maximum copies per toner cartridge.
4 Remove the paper protecting the toner cartridge.
fabric.
touching this area.
5 Hold the toner cartridge by the handle and slowly insert
6 Tabs on the sides of the toner cartridge and corresponding
7 Close the front cover. Make sure that the cover is securely
closed.
Good Luck!
Mar 30, 2010 | Samsung SCX-4300 Monochrome Laser...
What does it mean when the printer says "prepare new k cart"
It means that the black ink cartridge is going to be used up soon so you would better get a replacement at hand to avoid interruptions.Probably REPLACE K CARTRIDGE will appear sometime later.
To replace cartridge do as follows:
Get a Black (EP-87) Toner Cartridge.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [MAINTENANCE], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [CHANGE CARTRIDGE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the cartridge to be replaced, then press <Set>.
    Select [BLACK]
  5. Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
  6. Make sure that the toner cartridge you want to replace is at the position for replacing.
    Ifthe spent toner cartridge is not in the replacement position, close thecover, then open it again when the sound of machine stops. Repeat thisprocess until the cartridge you want to replace is in the correctposition.
  7. Remove the toner cartridge from the machine.
  8. Confirm the color of the label on the toner cartridge holder,then take out a toner cartridge of the same color from the protectivebag.
    • Keepthe protective bag in which the cartridge came in. It may be requiredwhen taking out the toner cartridge for machine maintenance.
    • Becareful not to hold or touch the prohibited portions such as the sensoror electrical contacts. It may result in damage to the machine.
  9. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
    • Iftoner is not distributed evenly, it may result in a deterioration ofthe print quality. Be sure to carry out this procedure properly.
    • Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
  10. Remove the protective cover. Hold the protective cover and remove it as shown in the figure.
    • Donot touch or hold the developing roller. The image quality maydeteriorate if you do. Do not apply shock to the toner cartridge memoryor bring it near magnetic waves as this may result in damage to themachine.
    • Keepthe protective cover with which the cartridge from removed. It may berequired when taking out the toner cartridge for machine maintenance.
  11. Place the toner cartridge on a flat surface, then pull out thesealing tape (Approx. 45 cm (17.72") in length) while supporting thetoner cartridge.
    Ifthe sealing tape is pulled out forcefully or stopped at midpoint, tonermay spill. If toner gets into your eyes or mouth, wash it awayimmediately and consult a physician.
    • Donot pull the sealing tape diagonally, upwards, or downwards. If thetape is severed, it may become difficult to pull it out completely.
    • Pullout the sealing tape completely from the toner cartridge. If thesealing tape remains in the toner cartridge, it may result in adeterioration in print quality.
    • Dispose of the sealing tape according to local regulations.
  12. Hold the grip on the toner cartridge and install it in the machine.
    Whenthe toner cartridge is installed properly, the label on the cartridgeand on the toner cartridge holder will be aligned as shown in thefigure.
  13. Close the cartridge cover and lower the scanning platform.
Nov 27, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
The color images have vertical banding or streaking but the text appears fine. the occasional blace and white image doesn't seem to have this. what can we do to fix the problem? thanks!
Good lunk attempting to follow solution #1, intended for an ink jet printer. LOL!
It seems like you are low on toner for one of the cartridges.
First, try taking out a color toner cartridge, hold it horizontally, and shake end-to-end. This loosens any possible clumps of toner and reactivates static charge between the particles. Repeat this for each color.
Second, print a color page with each toner color separate. For example, a line of cyan text, a line of yellow text, and a line of magenta text. This will help isolate which cartridge has the problem.
Third, check the toner level of each problem cartridge. There is a little clear window on the cartridge you can use for this purpose. Hold the cartridge vertically and tilt slowly toward the side with the window. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option). Otherwise, there is likely a different problem, for which I only recommend replacing the cartridge.
Don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, it will likely be nearing capacity.
Aug 16, 2009 | Konica Minolta magicolor 2430 DL Laser...
Doc. Cover Open displayed
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Canon NP 7130 Black and White Copier Logo
185 people viewed this question
old marine
old marine
