Question about Dryers
I have an eziloader 7kg washing machine it washes fine but when it gets to the drain part it isn't draining??? Pls help
You could try swiching the buten from dripdry to spin dry.
Posted on Mar 18, 2011
Simpson eziloader 7kg won't drain water?
check the pump hasn't got something stuck in it
Sep 10, 2013 | Washing Machines
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
Apr 26, 2012 | Electrolux Washing Machines
LG Intellowasher 7kg WD-1255FHB not draining properly
try draining to a different place . my system does not drain into something that can get plugged with leaves
Nov 01, 2017 | LG Washing Machines
I need a user manual for my 7kg EZIloader front loading Simpson washing machine
Google the make and model and add the words user manual to the end. There you will see numerous sites that offer either free or inexpensive user manuals that you can order or download. My favorite site is simply manuals.com.
Sep 04, 2011 | Washing Machines
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Hi hotpoint 7kg washing machine ultima digit washes fine and spins etc but i keep getting f05 flashing on display what do i do
Hi there usually the FO5 Problem is pump draining problem, check the U Bend under your sink for blockages also the outlet pipe for blockages, you may even need to take of the front lower panel and you should find a small pipe and you can clear and drain water from that also and clear of any bits. hope this helps
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Dryers Logo
94 people viewed this question
Top Dryers Experts
