Question about Dyson Vacuums
The power bar button does not engage the power bar.The on-off switch works.the power bar still works but will not run if you dont hold it on.
4 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: dyson dc17 power on/off button will not engage when pressed
The on/off switcdh underneath the button sounds like it's faulty and will need replacing. I would suggest caling Dyson in your country with the Serial No of the unit for guidance.
Posted on Mar 25, 2009
SOURCE: power switch will not engage.
Possibly the micro switch is faulty or the switch isn't in its proper position in the machine. It could be a cable problem too. An electrical continuity test (with the power off) should prove where the fault is. hope this helps.
Posted on Sep 03, 2009
VacuumRepair
  • 438 Answers
SOURCE: power switch does not work
Greetings,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums. The switch that Dyson uses for their vacuums is one of the cheapest quality switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Plyers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya. If this repair was helpful to you, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand coner. This is a nice gesture that will ensure that professionals will continue to post free repair solutions here on Fixya.
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
Posted on Apr 03, 2010
The Dyson roller ball vacuum I have is making me crazy because the roller bar wont turn. What gives?
Check that you dont have anything blocked in the roller, if all is clear there is a little red button on the side off the roller. Push this in and this will reset the roller... If that doesnt work, check that it is switched on with the switch next to the power button.. That should solve your problems
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Nov 08, 2009 | Dyson DC14 All floors Bagless Upright...
Power switch will not engage.
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
On switch will not stay down or on
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great, it should now stick when you press the power button. Replace it and reassemble, otherwise you'll need to get a new switch.
May 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 power on/off button will not engage when pressed
Mar 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC14 animal
this may sound harsh and i apologize in advanc. but dyson vacuums are just over priced pieces of junk. you would have gotten better quality out of a 39.00 bissell and now to the repair. the machine is made of cheep plastic which wears and breaks over time. the power switch, and button will have to be replaced which will cost you rougly around 70 bucks. and that is if you do it yourself. the beater bar stop could be a broken engage bar as well. meaning when you turn the nob to hard wood or to floors it turns the beater bar off, but when you turn it to carpet it kicks it back on. the mechanism that does that could be broke as well. i would make dyson warranty the vacuum if it is still under warranty. if it isnt i will say it is not worth the repair costs to keep it. im sorry to have to say this but they are disposable vacuums they are not built with quality.
Aug 09, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
171 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
