How many BYU is a Lennox G40UH (x) series furnace? And can it be vented with PVC? Thanks alot!
    Brigadier General:
  • 4,736 Answers
The Btu rating for this furnace is 40,000. Since the furnace has a 3 /34" metal flue collar on the top of the unit, you can not use PVC pipe to vent it. Only 90+ efficient gas furnaces can use PVC pipe for venting and the also come equipped with a condensation pump, which yours doesn't.
For more information on your furnace and how it's to be safely installed and vented, here is a link to the installation manual http://www.greenwoodheating.com/products/manuals/gasfurnaces/G40UH.pdf that you can download and print.
Hope this helped answer your questions?
Posted on Mar 18, 2011
The air conditioner is hooked up to my lennox furnace and it is leaking water...is there a drip tray or drainage hose that could be blocked?
On your inside lennox furnace there should be a 3/4 inch pvc pipe coming off the evapartor coil this is what gets stopped up and you need to take a shop vac and clean it out.
Aug 01, 2011 | Heating & Cooling
Can I vent my ultra v tech 80 propane gas furnance with pvc so I can do away with chimney
Generally, the furnace must be at least 90+ efficiency to be able to use PVC pipe. In addition, high efficiency gas furnaces require a condensation pump, to pump excess moisture out of the furnace. If yours has always been venting up a vent pipe, then NO, you can't use PVC pipe.
Hope this helps you.
Mar 14, 2011 | Heating & Cooling
Lennox G40uh model, blower work, but does no ignite.
Jump out the pressure switch once the inducer blower starts. If it lights, you have a bad switch or the vent is obstructed. Is the unit blinking any error codes at the PC Board?
Mar 07, 2011 | Heating & Cooling
How to install the intake air supply and the exhaustvent on a high effeciancy lennox G26Q4/5-125-6 Furnace
hi i am a lennox dealer and can help you with this problem i also have an instulation manual for this unit its going to be scud. 40 pvc pipe both the intake and supply have to be vented out side email me at airforceac@live.com
Aug 11, 2010 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
No cool air some rooms: Lennox G40UH
Sounds like a restriction of air flow. Check you duct work and check for holes or lose duct.
Jun 30, 2009 | Goodman CKL24AR24 Air Conditioner
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
27 year old Lennox gas furnace no heat was coming out of the vents, so I went to the basement and saw 1. One burner was clogged all along the surface and instead of the flames going up the flue, they were...
Please get a furnace that thing is seriously a death waiting to happeng.that is a scary thing to happen. I personally have seen the end results. In the mean time space heaters are safer.
Mar 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
486 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
