Question about Samsung Cameras
How to remove an SD memory card from a Samsung L100 camera
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
Samsung L100
See page 15:
To remove the card simply press on the end of the inserted card & it should pop out.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 02, 2008
The card is locked and i cant take pictures
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 03, 2011 | Samsung L100 Digital Camera
My camera did not come with a usb cord so how can i get the pictures off of my samsung l100? With my memory card? If so, how would i do that?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 13, 2010 | Samsung L100 Digital Camera
When taking a shot camera reads card lock
I guess that perhaps your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 17, 2010 | Samsung L100 Digital Camera
L100 Digital Camera: keeps saying card locked...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 17, 2010 | Samsung L100 Digital Camera
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
Card error on L100 samsung camera, help please.
copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
Mar 04, 2009 | Samsung L100 Digital Camera
SAmsung L100
take out the memory card look for a lock tab at the side of it, push it up and insert the memory card back. that should do it
card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
hope this helps
Feb 01, 2009 | Samsung L100 Digital Camera
Samsung L100 digital Camera
remove the memory card and slide up the lock at the side of it
Jan 28, 2009 | Samsung L100 Digital Camera
MY PC NO RECONAISE DRIVER sUMSUNG
>turn the unit OFF connect the camera to your PC,
>then turn it on,
>wait for the camera screen to display a selection
>pick COMPUTER,
>your computer should detect it as a REMOVABLE DEVICE
>open that
>you should see a DCIM folder open it again and >
your should see SSCAM 100, SSCAM 101 folders
each folder consists of 100 images that you took, the camera will automatically create a folder for every 100 pictures you take
hope this helps
Dec 21, 2008 | Samsung L100 Digital Camera
Cameras Logo
108 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
