Question about Sport & Outdoor - Others
I have a 4300ss penn fishing reel that the anti-reverse feature does not lock or in other words the bail locks down fine , but the rell will free turn when it is supposed to lock and only work against the drag ?
You need to take apart the reel and pinch in the leaves on the antireverse dog.
Posted on Mar 27, 2011
Penn 4000 Battle. How do I change the direction of the spool?
Reel only retrieves in one direction. If you turn the anti- reverse button off(lever under spool)You are able to retrieve in reverse.
May 18, 2017 | Fishing
How to fix Defiance 25LW that will not cast (or free spool)
Those reels are very simple, nothing too complex about them at all, sounds to me that the clutch gear is stuck not and not releasing when you try to engage it. I've had similar bait caster lock up like that when trying to cast heavier baits, what happens is the spool spins so fast that the inertia and vibration causes the reel to actually engage mid cast slamming the gears together. not good for the gears by the way. more that like the reel needs to be opened up and looked at to resolve the issue. www,darksidereelz.com for all your reel service needs
Jul 09, 2014 | Penn Defiance 25LW 66" Combo
My penn 4300 ss, the bail won't close on it's own when I rotate the handle, I can close it manually. I have 3 other 4300's that work fine
You need to either replace the bail spring or release any tension cause by the bail wire gap being too wide or to small. Take apart the bail wire and adjust the gap so that it doesn't bind when closing the bail.
Mar 19, 2011 | Penn Gt Series Levelwind Reels 330GTi
My penn 950SSm reel doesn't lock out the handle spins backwards and lets out line after casting it and bail is flipped back how do i fix this
Try flipping it forward.. if that doesn't work... there must be a small spring inside broken. Just take it completely apart on a table. once apart look at the bail assembly, u should be able to find the broken piece. Take both broken pieces down to your local hardware store and ask someone for assistance. Someone should be able to help you find a piece very similar.
Oct 30, 2010 | Penn Spinfisher 950SSm Saltwater Spinning...
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Sport & Outdoor - Others Logo
275 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
