Question about Frigidaire Washing Machines
Frigidaire front load washer. had problems with drain and spin,went through everything i have seen on here.was working until i put a large load of towels in. half way through the load sounded out of balance and stopped. removed everything got the water out now wont start. when i hit the start button it sounds like it is going to start makes a click when water is supposed to start but nothing but a buzz.ran through all trouble shooting everything worked until agitation or spin. belt is fine and spins freely
    Sergeant:
  • 170 Answers
Door latch could be messed up from the large load//do you here the door lock when you start it ? if door is locking and basket is not turning at all even for adjitation then it is most likely the motor control board that board is located at the bottom of washer remove lower kick plate.if you inspect that board you may find a burnt spot. that can be caused from the overload of the motor /check those things let me know how you make out..good luck and thanks for voting
Posted on Mar 18, 2011
Testimonial: "the board had a burnt spot. can that board be repaired?"
  • Czerney Dort Mar 20, 2011
    NO that is a complete replacement part called the motor control board I may have one if you lived close to me?
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer is not spinning but water comes in and is pumped out. Nancy
Had the same problem, it was doing everything it should until it got to the rinse and spin. It was draining but slowly then wouldn't spin. We found it was a clogged drain pump. We cleaned it out and now its like new. Try reading the codes.
Sep 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Side load washer spins cycle problem.
Clean your drain valve. The water is not pumping out. This puts a strain on the machine.
Remove the bottom front cover to access the drain valve.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
