Question about Dell OptiPlex SX280 PC Desktop
I can't get my internet up and running. How can I do it, is it maybe a cord in the wrong place?
    Master:
  • 325 Answers
The internet cord can only fit in one place (assuming you are broadband)
right click on my computer click properties click hardware click device manager
you should se a icon saying [+](picture)network adapters
if it says [-](picture)network adapters L(picture) whatever make or model network adapter and a yellow (!) next to it you have a driver problem, search and reinstall the driver.
Posted on Mar 18, 2011
Why does it pop the reset button?
The button is a current overload protection for the motor. There is a variety of causes. Defective motor windings, carbonized burnt pressure switch contacts, loose connection (e.g. cord to plug, switch terminals, motor terminals), wrong voltage supply to the motor, worn motor bearings, drive belt too tight, or defective driven machine.
I would run the motor with no load, remove the belt or coupling to the compressor pump, and read the amperes and compare to the motor nameplate rating, let it idle a few minutes and listen for bearing noise. By reading motor amperes or current while the compressor is still connected to the motor, it can be determined if the reset button/overload protector is weak. Check every electrical connection for discoloration or overheating and repair if any are found. Check the contacts of the pressure switch. If nothing wrong is found and the motor is just overdrawing current or amperes, then it is time to replace the motor, probably due to a weak or defective motor internal winding.
May 27, 2015 | Air Tools & Compressors
Honda gcv160 governer problem
try looking at anotherone and look at the long wire cord maybe u took the carb off and didnt put it in the right hole..or forgot to put the spring on or have that in the wrong place the honda carbs suck it goes in and out when the carb is faulty..check the carb get it rebuilt or just change the pin on the float..
Nov 18, 2012 | Husqvarna 21" Lawn Mower with Honda GCV160...
Power on but nothing on screen
maybe the cords are not correct. and when the system shuts down does it blink red?
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
My dryer all the sudden is blowing the fuse at the panel. It runs for a short time and then blows the fuse. Sometimes it just keeps running and doesent blow the fuse. It is hooked up properly and has never...
UNPLUG THE CORD then,.,,,maybe the cord hooked to the dryer terminal block and just follow the cord to the unit and take off the axcess panel to power cord hookup is shorting out and needs to be replaced being hooked up properly is why its the first place to look for its
Aug 26, 2009 | AEG Dryers
Wifi can dtects signals, but no internt
Maybe, the router is not allowing the connection to the internet. It can also be that the cable from the modem to the router is not placed on the right slot.
Jun 12, 2009 | Toshiba Satellite U305-S7448 Notebook
Inspiron E1505 - Bad ethernet connection
right clik onmy network places chekc your lan card is enable?
if not enable it.
Nov 01, 2008 | Dell Inspiron E1505 Notebook
Connecting to the internet
Your settings in the phone maybe in wrong so it would be best to speak to your mobile provider and have them assist you with manually placing the gprs settings back in the phone
Sep 29, 2008 | Motorola Mobility RAZR V3
Keep getting disonnected from internet when using laptop power cord
weird problem you got there huh, just try to reinstall the wireless or built in lan card driver, is the power adapter near the lan cable outlet? maybe its just loose, try to use wireless connection in the internet
Apr 05, 2008 | Computers & Internet
Dell OptiPlex SX280 PC Desktop Logo
Alun Cox
