Question about Lightware VP 800 Plus Multimedia Projector
Looking for part
I have a lightware vp 800 plus : What is the name of the diamond shape glass that sits underneath the bulb. It shattered from the heat of the bulb. Where can I get one?.
  • 3 more comments
  • Anonymous Dec 19, 2008
    I have the same problem.
  • luc_ou Jan 09, 2009
    hello, I had the same problem bot don't resolve. My lamp had overheat.
    If you have the solution, can you help me.
    luc_ou@hotmail.com
    tanks
    I'm gona try to do that for you to
  • jacobs76048 Jan 26, 2009
    Same here. This is the second lightware projector that has that diamond shape glass shatter. I would like to know the part name/number and where I might find it. Also thinking it would be a good idea to check the internal fan out. If anyone knows what the "diamond shape" glass is that is located behind the bulb please pass it on. We can still use the projector but image is darker and sometimes difficult to see.
  • bmnoll Feb 17, 2009
    Hi All,
    That part is called the condenser lens. It apparently focuses the light and makes the projection look brighter. I have also read that the lens may help shield the lcd and mirror from the heat of the bulb. The projector can run without the lens but I would be worried about the buildup of heat and of course the brightness.
    I have been searching for a replacement lens today without luck. Someone has posted the dimensions of the lens here (for those looking):http://img22.imageshack.us/my.php?image=...
    D: 63.6 mm H: 28 mm
    My lens broke today at bootup. I'm not sure what happened, but I have read that the lens should not be exposed to sudden temperature changes and should not be moved when hot. I have been opening the bulb door each time after operation to let it cool down, so maybe that is what did it in. Or perhaps the bulb was just too hot, this is what I was using:http://www.divinelighting.com/evdl-200-h...
    Anyhow, here is what I have found so far: http://www.surplusshed.com/search.cfm?Se...
    https://lumenlab.com/forums/lofiversion/...">
    Please post if you have any more leads.
    Brad
I think it's the long-life bulbs... mine just shattered too.
anyone have a part-number/company?
Posted on Sep 11, 2010
After my vp800 plays for a hours it cuts off. WHY?
Remove the cover and check whether the air filters blocked with dust.
Whenair filters are blocked, air doesn't flow freely through the projector. This result in overheating, leading to automatic shutdown.
Sep 21, 2011 | Lightware VP 800 Plus Multimedia Projector
Lightware VP100 has no sound
make sure the internal speakers are on. go through the menu under settings to find out and to turn them on.
Sep 09, 2009 | Lightware VP 800 Plus Multimedia Projector
Two bulbs?
it needs one to work,is better when you installe two,so when is burnt out you just need to slide the other one and continue the show.
Apr 07, 2009 | Lightware VP 800 Plus Multimedia Projector
My Lightware VP 800 fan turns on but when I press the power on button it powers up but no light comes on. The bulb does not need to be replaces. any ideas?
Check the bulb with a multimeter or it could be the ballast .Lots of times it an easy solution like trying another ac cord that fits better or even the ac fuse.
Mar 02, 2009 | Lightware VP 800 Plus Multimedia Projector
Manual for lightware vp800, and i can't get the sound to work
Try changing to your S video wire input.If you hear a cracking sound it could be you've blown your speakers.It depends on your application but I run all my DVD equipment through my stereo system,just run the same video wire to your stereo and select that input on the stereo .And yes they do have remote controls,try ebay where you can get another vp800 w/remote under 100.
Dec 22, 2008 | Lightware VP 800 Plus Multimedia Projector
Won't turn on.
It is cheaper to buy a used one off of ebay than have it repaired.It is so out dated that most shops won't touch them.If you buy another keep the old one for parts ,they are great little projectors.
Dec 16, 2008 | Lightware VP 800 Plus Multimedia Projector
I have a Lightware projector Model VP-800. It won't power on. Do you have a repair service in the 13211 zip code area?
good luck finding anyone to fix that, much less anyone who carries parts. you can try finding a service center by searching the lightware site.
Skewness
Hi! I think I may have your anwser. Make sure your moniter resolution is set to 800 by 600 in you display setting on your windows PC. If your running windows XP, right click on your desk top and click "properties" and go to the tab settings. I HOPE that helped :)
Aug 13, 2008 | Lightware VP 800 Plus Multimedia Projector
Lightware VP 800 Plus Multimedia Projector Logo
154 people viewed this question
Top Lightware Office Equipment & Supplies Experts
jasbo
jasbo
Piyal Perera
Piyal Perera
Bill Boyd
Are you a Lightware Office Equipment and Supply Expert? Answer questions, earn points and help others
