Question about Linkskey (LKR-604) Router
The router assigns an IP address, etc. to my PC and I can ping 192.168.0.1 and get a response. However, I am unable to access the router for configuration using either IE or Firefox. The network troubleshooter says it refuses the connection. I have reset the router with the reset on the back.
    Sergeant:
  • 223 Answers
Thank you for using FixYa
Sounds like you have the right address 192.168.0.1. When resetting hold the button in for 30 seconds. Also it may be your firewall preventing you from getting into the modem. Try turning off the firewall in Windows and try again. Since it returns with the device attached the computer is still seeing it, but if it had bridged before, it may still be in bridge mode and passing the signal. Don't forget when you get it to reset you will have to configure it again and put in the default password.
Here is the direct link to your manual.
http://docs.google.com/viewer?a=v&q=cache:yxBNlH1fJ98J:www.linkskey.com/drivers/linkskey/LKR-604_User_Manual_R.B.pdf+LKR-604&hl=en&gl=us&pid=bl&srcid=ADGEESh8R9cffaF7_Tf31ULy2PKwdsKc50L9mJl9emHCKG-weQ8VapryxTeOSCKpR5qQXftuC5lfg-EbBD_M2mi9rvdveIbwj0hhSvVTAIgnk-oKT0YnWIuEMa9jAxjRLEaghZrbWGWJ&sig=AHIEtbRSZgy9UUaMVzYR6dqrKhcynONbnQ
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 18, 2011
  • 415 Answers
If you're connected with wifi you may first need to connect it through the LAN (wired). You also must have your pc tcp/ip (NETWORK CONNECTIONS) configured so that the gateway number is the number of the router in order to get out on it. Then you should be able to go via the webpage interface onto the router. Check the gateway number first. If you set up a wireless with a wep or wap key you will need to have that before you can get on the router too.
Belkin f9k11009v1, Macintosh unable to connect
First see if you are able to connect to the internet wired to the router,
-If you are able to connect using the wire connection then I suggest to turn off the wireless security settings for the time being and see what happens.
Wireless
See if you are able to ping your router.
Ref: http://www.wikihow.com/Ping-on-Mac-OS
-Make sure that the TCP/IP settings are set to DHCP and make sure that it is getting an IP address and Default Gateway.
If you are able to ping the router then see if you are able to ping google by name and by IP. (An IP address for google,com is 74.125.141.100)
If you are able to ping both then you should be able to access the internet.
If you are able to ping only the google's IP address then you have a DNS issue.
-See if you can set your DNS address manualy to 8.8.8.8 and 8.8.4.4. Ref: https://developers.google.com/speed/public-dns/
If you are able to ping only google by name then see if you are able to access google by typing in the replied IP address in the address bar of your web browser on a computer that is working fine.
-If you are not able to access google with the address then you may have something stooping you on your machine. Check for firewalls and antivirus to see if they have any network configurations.
Dec 18, 2012 | Belkin F5D7234-4 Router
Can't access internet, all lights are on
->First,restart your computer
->Open web browser and enter the IP address and enter the login details on the login screen and proceed.Click Router Status under Maintenance and check if you see your IP address.
->If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
->After configure you router ,open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
->If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping IPaddress(ex:192.168.1.0)', hit Enter.
->If you get the Request timed out message then check your router connection again and correct the Ethernet connection between your PC and the router.
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Nov 14, 2012 | Belkin (F5D7230-4) Router (587009)
Ip address in invalid on windows vista
All we need to do is to reset the router for about a minute, if we are still getting invalid IP which is 169.x.x.x then we need to temporarily assign an ip address on the computer.
How to assign IP address:
Windows XP
Step 1: Click Start, then Control Panel.
Step 2: When the Control Panel window opens, double-click Network Connections.
Step 3: Right-click Local Area Connection, then click Properties.
Step 4: When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then Properties.
Step 5: Change the option from Obtain an IP address automatically to Use the following IP address and enter the following:
Make sure the IP Address you'll be assigning the computer has the same first three numbers as the Default Gateway and the last number can be any number between 2 and 99. In this example, our Default Gateway is 192.168.1.1, so the IP address that should be used must start with 192.168.1. In this example, the IP address that we'll assign is 192.168.1.50.
  • IP: "192.168.1.50"
  • Subnet Mask: "255.255.255.0"
  • Default Gateway: "192.168.1.1"
After assign static IP then click OK.
Step 6: If we are not getting any response from the router(like pinging the ip address of the router) then possible product is defective.
Dec 22, 2010 | Computers & Internet
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Connection issues
To troubleshoot the issue follow the below steps
1.Try disbaling and enabling the wireless lan card
2.Check whether Ip addresses assigned in the wireless network card.If the address is assigned by dhcp and not assigned in network card means assign static ip in the range supported in the networkand ping the website or gateway.
3.If the ip is assigned already means try pinging the gateway and dns server .If ping is success means the connection between router and pc and internet is good .In that case you have to check whether authentication is successful if any authentication is used.
May 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
Internet connection problems
Troubleshooting Internet Connection Problems The purpose of this section is to give general tips
on troubleshooting your Internet Connection
While there are many possible configurations, I'll try and cover the most common ones.
Making Sure You Have Correct IP Information
Basic PING Tests
Browser Configuration
Making Sure You Have Correct IP Information 1. Make sure you have the correct IP scheme for your network. This would include the:
  • IP Address
  • Subnet Mask
  • Default Gateway
  • DNS Servers
2. There are a few ways you can see what IP addresses are being assigned.
But generally for:Win9x - Start / Run / command
Windows2000/XP/Vista - Start / Run / cmd
The run IPCONFIG /ALL. A sample where a router is used is in the following graphic.
ipconfig.jpg 3. IP Address:
If you have a router, common examples would be:
192.168.0.x, 192.168.1.x or 10.0.0.xIf you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
What you don't want to have is something like 169.254.x.x. This means you are not getting and IP address assigned and needs to be resolved first.
4. Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0 5. Default Gateway:
Make sure you have the correct Default Gateway IP address.
With a router, this is typically the IP address of your router. 6. DNS Servers:
Make sure you have the correct DNS Servers. Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
Sometimes (as in this example), it is the actual DNS servers used by the ISP.
7. Possible causes for not getting an IP address assigned are:1. Defective cable, network card or port on the router. Make sure you are using all known working components.
2. Your router is not configured for DHCP (which would automatically be assigning IP addresses).
But you need to have this correct before proceeding.
Basic PING Tests 1. This and can be done from that same command prompt you used to run IPCONFIG 2. Try pinging the router's IP addresse.g. ping 192.168.1.1
If you get a reply, then your connection to the router is working.
If you don't get a reply, then you need to double check your network card, cable, port on the router. You might also see if any other computers on the network can do the same.
3. Try pinging an external site by IP address e.g. ping 4.2.2.1
If you get a reply, then you have a connection to the Internet.
If you don't get a reply, there are several things you can try:
1. Double check that the router is connecting to the Internet. Typically you can access the router through your web browser and check it's status.
2. Take the power off your DSL/Cable modem and Router. Plug the modem back in a wait a minute or so. Plug the router back in and wait a minute or so. Then restart your computer.
3. Winsock Fix - It is possible that the Winsock Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Namee.g. ping www.yahoo.com
If you get a reply, then you have a connection to the Internet and DNS is working
1. Double check your DNS entries
2. You many need to use the same DNS IP address that your ISP or Router is using.
3. On rare occasions your ISP has problems with their DNS servers. But that is rare in comparison to misconfigured computers.
If your PING tests work but you are having problems browsing sites on the Internet 1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured. 2. Double check that you don't have an incorrect or not needed Proxy server assigned.For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Mar 28, 2010 | HP Pavilion dv9720us Notebook
Hello, i type in the modems address, 192.168.0.1 but it wont let me access the setting page to try to configure wireless settings, i'm running win 7 64 bit, and cant even find a dos command to ping with
To get to the DOS prompt , Go to start and type " cmd" enter. Then you can use the ping utility. I had a problem on a new dsl modem and after many hours trying to fix it, It was a bad modem. It worked for a week then nothing. They finally replaced it and it worked. Some time being new doesn't mean its not broken. I learned it the hard way.fd93cca.png
Dec 18, 2009 | NetGear DG834G Router
ENHWI-G2(NE)
I would suggest setting the IP, Gateway, DNS and proxy (if it exists) statically on the devices... Just use one compatible with your network (something DHCP would assign for an ip).
Jul 17, 2008 | Encore ENHWI-G-RLAM 4-Port Wireless-G...
Power indicator keep on blinking
hello!
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
Linkskey (LKR-604) Router Logo
104 people viewed this question
Top Linkskey Computers & Internet Experts
David Payne
David Payne
Are you a Linkskey Computer and Internet Expert? Answer questions, earn points and help others
