Question about Yamaha Audio Players & Recorders
Hi, Yamaha - I just today purchased a new RX-V467 Receiver. I'm getting it set up, have the CD player working - but I have a question - I'm using a separate EQ unit that hooked into my old receiver's tape monitor loop. Can I use the spearate EQer unit with the 467?? How do I hook it up, so that I can process the signal both for recording, and for playback?? I see reference to this is the manual, but I want to make sure I'm doing it right before I start unplugging things....that could get very confusing... Also - which is preferable - to plug the CD player into audio inputs 1 or 2?? or into A/V inputs?? does itmake any difference?? TIA, Dave Gallagher dgallagher4@comcast/net.
  • dgallaghe340 Mar 18, 2011
    Hi, BElectric - thanx for your response - at this point - I would only unput a cd player, and a tape deck into the EQer. no TV.
    the way I had it before, i fed two cassette decks and a reel-to-reel machine into a switching box, and then ran one line to the EQer....then I ran that line out into the receiver. I still have that box , cables etc.
    "You also need an audio out from the receiver direct to your recording device bypassing the EQ."
    yes I would like to do that - right now, the cassette deck is the recording device, but I've been thinking of adding/replacing it with a digital recorder of some sort. I'd like to be able to process the sound.
    how do I set up the "audio out" from the receiver to the recording device??
    the EQ I use is an AudioSource EQ100 it has the following input/output jacks:
    Audio IN [from rec'ver]
    Video IN [not in use at present]
    Main OUT [to receiver]
    then it has its own tape loop -
    Tape In [play]
    Tape out [record]
    Thanks,
    Dave
    President:
  • 1,140 Answers
Hello Dave -
To use the EQ for both playback and recording, ideally you would need to connect all of the audio inputs (CD, TV, DVD, etc) directly to the EQ and then run one connection from the EQ to the receiver. You also need an audio out from the receiver direct to your recording device bypassing the EQ. Basically, you need to process all of the audio signals pre-receiver.
You can connect the EQ to the AUDIO 1 or 2 input sockets or the L/R AUDIO IN sockets of AV inputs 5 & 6. AV inputs can be used for audio only. It's more logical to connect audio only devices to the AUDIO IN sockets, but as long as you select the correct input on the receiver, it's not vital to do so.
This is a fairly basic explanation. If you need further assistance, I will need to know the brand and model number of your EQ unit to see what inputs and outputs are available. It would also help to know how many devices you want to connect to the EQ and what they are. It you're trying to run video via the receiver to the TV as well, it's going to get more complicated.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 18, 2011
  • DILLIGAF
    DILLIGAF Mar 18, 2011
    Hi Dave,
    Thanks for getting back to me.
    There are a few ways to do this, but I'd suggest you continue to use the switching box as before to avoid any crosstalk from the audio sources. Then run one line from the switch to the EQ and one line from the EQ to the receiver. I'd suggest using the AUDIO 1 or 2 inputs on the receiver for this, but you can use AV 5 or 6 if the dedicated audio inputs are being used for something else.
    With regard to recording, you could continue to use the TAPE OUT from the EQ as before. Alternatively, you can connect the tape deck to the L/R AUDIO OUT sockets on the back of the receiver. The sockets output at a constant level which is not affected by changing the listening volume on the receiver. If you want to add a digital recorder and still use your tape deck for recording, use both the TAPE OUT on the EQ (ideally for the tape deck) and the L/R AUDIO OUT on the receiver for the digital recorder.
    As you are using a separate EQ, you should also use the DIRECT mode on the receiver as this switches off the audio decoders in the receiver so there is no additional EQ / audio processing. Multiple EQs can be quite confusing and the EQ on the receiver has more limited adjustment and fewer frequency ranges than your EQ unit.
    Hopefully, I've answered all your questions so far, but if you have any further questions, please let me know and I'll get straight back to you.
    Regards,
    BElectric
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Why there's no onscreen display on my yamaha receiver, the power is on?
Open the YMHA chaik cable for display and chaik may display gone may inside led gone internal problem some fuse r ic chaik
Aug 31, 2014 | Yamaha RX-V467 Audio video AV Receiver for...
Hi, have Yamaha RX-V467 receiver hooked up as follows: directv sat to Yamaha receiver via HDMI. blu-ray to receiver via HDMI. Receiver to Sony lcd tv via HDMI out to TV. Have 2 problems when watching TV...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-RX-V467-Receivers-review-manual/id/23658bh533/t/1-2/
1) How is it with FM? That -35dB may be normal for this receiver. My old Pioneer is exactly like yours, inaudible at -50, whisper-quiet at -35 on all sources. But it will still crush my skull if I want it to.
2) Page 72. Press STRAIGHT to toggle out of Straight decoding mode.
Apr 24, 2011 | Yamaha RXV467 Receiver
Hi. I bought a yamaha rx-v467 amp from usa and it only supports 120 volt. Will it take australias 240volt power if i plug it in. There is no voltage selecter on this one! Will i have to run a voltage...
I think so...I looked at the specs on this and it does not have provisions for 240V. You're going to need a step down transformer from 240VAC to 115VAC.
Jan 30, 2011 | Yamaha RXV467 Receiver
How do i program for sony cd player
I also have a Sony CD player (CDP-XE330) and I have tried almost every code from the yamaha manual, but without success.
The only codes that yamaha remote supports, are the codes from the list in the yamaha manual. If none works, you are out of luck and the only solution is using the original sony remote (if you have one) or universal remote.
I have recently purchased Logitech Harmony 525 on eBay and now I control all my 7 devices with it without any issues. It is programmed via USB and Logitech has codes for almost 250.000 devices.
Sep 16, 2009 | Yamaha RX-V361 Home Theater Receiver
Yamaha remote to command Sony CD changer.
isn't that nice of them to just list the yamaha code for CD players? I sent yamaha an email about it. we'll see what they say...
have you checked out the new universal remotes that are out now?
http://universalremote.com/consumer/products.php
http://www.compuplus.com/i-Universal-Remote-Control-URC-R50-Digital-R50-Universal-Remote-Control-1028369~.html?sid=jn84494w6bxh2e2
Feb 26, 2009 | Yamaha RX-797 Receiver
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Sep 16, 2007 | Yamaha RX-V596 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
