Question about LG DLE2516 Electric Dryer
I hooked up my Dryer in a different house and when I plugged it in it powered up and ran for just a few seconds and quit then I noticed a burned rubber smell. The light works when opening the door but there is no power to the control panel when I push the power button. I did not know if there it has fuses or not or what else it could be. thanks tanner
  • LG Master
  • 2,605 Answers
Hello, Welcome to Fixya. It sounds like the belt may have broke or come off and activated the "kill switch". I'd also suggest you check you have 240vac to your plug and also into the dryer side of the power cord. Can you confirm this is indeed an LG dryer model DLE2516 as I think there was I repair tip on those I'll need to look up. I think I have a service manual on my PC but I won't be able to check until the "AM". I'm on my iphone and the PC is off for the night. It is approx. 11pm mtn time where I am so if you can wait I'll find it and provide more info. If you are fine with waiting until morning do not reply as that will automatically push me out of your solution post four hours after you reply If I dont post back, and I wont be able to as I will be sleeping and unable to reply. I will post first thing in the AM. Thank you for choosing FixYa. Hope to talk again soon and provide more info. Regards, Macmarkus :)
Posted on Mar 18, 2011
  • Mark MacDonald
    Mark MacDonald Mar 18, 2011
    Hello again,
    Just following up on my previous post. I looked into any "repair tips" for that specific LG dryer and there are none. Some of the LG dryers had revisions made to the control board, your's (LDE2516W) isn't one of them.
    As I alluded to previously, I'd start by checking the belt, likely easiest to simply reach into the drum and turn it by hand, if it spins freely it likely is the belt, if however there appears to be "drag" it likely still has the belt attached.
    You can also feel through the back for air flow as you spin the drum, if the belt is attached the blower will spin as well therefore if it has no air flow the belt has probably come off or broke.
    The other area I alluded to checking was the voltage supply to the unit...insure the dryer has 240Vac to it.
    If you are able to check these things and dismiss them being the trouble I'll assist you going forward in any manner I can. Good luck.
    I'll watch for your reply. Thank you for choosing FixYa today.
    Regards,
    Macmarkus :)
My dryer runs jus for few seconds an cuts off then cuts right back on its usually differant amounts of time till it cuts off
i would say your motor has had it but check with a new caps first but usually these appliances have a protection overload to prevent burning your house down
Jul 11, 2014 | Bosch Axxis WTA 3500 Dryer
GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Aug 01, 2008 | GE Profile PFS22 33" Artica French Door...
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Light underneath dryer, right side, front
What you`ve ``just started noticing...`` is likely the ignitor glowing or the burner burning and is quite normal for a ``gas`` dryer.
Hope that answer`s your question. If so please take a second to rate the reply I provided to you here at fixya.
Thank you.
macmarkus :)
Dec 13, 2009 | GE DBSR453GBWW Gas Dryer
Starter button quit
hello. if this an electric dryer, here are the possibilities, if it is a gas dryer get back to me.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 13, 2009 | Dryers
Is their a fuel pump in tank of E350 7.3 diesel 1988 ford ?
my guess is there is a fuel pump in tank as there are in 95% of diesel motor vehicles. you may have just sucked out the existing fuel from the lines. the fuel pump can withstand high amounts of amperage and voltage so by hooking up wires wrong i dont think you burned up the pump but you may have wired it up wrongly, or you have forgot to put the o rings back inthe housing properly. or drop on in tank. check the fel system setup. Orings in place, wiring connected properly. if all else fails give the pump a hit and see if it will start.
Aug 09, 2009 | Ford E-350 Cars & Trucks
I have a electric dryer but dont have the outlet forthe plug
You don't need to 'rewire the house'. You will need a 240 volt circuit ran for the dryer to work though.
Jul 09, 2009 | Dryers
Dryer quits running but heating element stays one
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 15, 2008 | GE Profile DPSR473EW Dryer
Asko T761 and W660 have power, but won't start
Have the plug checked.......kill power to it for now. Try the washer in a different circuit. It sounds like the circuit feeding the machines is damaged and is carrying enough voltage to handle the displays but cannot carry enough amperage to run them. Any time you smell burning around electrical equipment, it's a good idea to shut off the power to the equipment
Feb 25, 2008 | Dryers
LG DLE2516 Electric Dryer Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
