Question about GE Refrigerators
What causes water to build up on the top shelve? I do not where any water is leaking from the ice maker.
  • 3,018 Answers
Sounds like the drain hole on the bottom of the freezer is plugged. When that gets plugged normal condensation has no where to run off to and thus collects on the shelf itself. You might want to defrost the freezer completely and then take a little cup of water and pour it into the drain hole and make sure it cleared. Make sure nothing else is blocking the hole too but it starts with a defrost. Should fix you up.
Posted on Mar 18, 2011
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
Water falling from the ice maker to the freezer compartment
No, water pressure should not cause such a leak ,you possibly have a defective water solenoid ,if you trace the water inlet to your refridgerator you should encounter the solenoid which is a electrically operated valve , with power off you can disconnect the output side if there is a flow of water with no power to the fridge the solenoid is defective ,try to service the unit because any build up or foreign body can stick the plunger . If you can apply a 110v to the wires you should hear a click when energised.
If your solenoid is good the water sense timer is defective and keeping the valve open. Hope I helped
Oct 03, 2012 | Refrigerators
Ice maker is splashing water all over back of freezer and it builds up til the fan starts to make noise if I turn it off and defrost the ice it will start up noise free til the ice builds again.
What is the model number of your unit? When the ice builds up, does the ice just build up where it is splashing or is the ice also building up behind the back wall of the freezer?
Thank you! Richard
Jul 21, 2011 | Refrigerators
Water on floor of refrigerator and icemaker not working
You need to make sure the fill tube is not freezing over and causing the water to go everywhere but the ice maker. And again the ice maker may be a different problem. I have a link for you to go to and look over leaking freezers and refrigerators. But lets first make sure the water is coming from the ice maker or the defrost drain is blocked, Sea Breeze
Sep 19, 2009 | Frigidaire Gallery Series GLRT13TEW 30"...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Jul 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
