Question about Dishwashers
We have the Technika TDX6SS-2 and the heavy, fast and pre-rinse buttons are flashing and beeping - stops momentarily then commences again. There is no way to stop this. Could you please help with this problem? Thanks, Deirdre
  • madmat77 Sep 01, 2008
    same problem.unsure on how to fix.please help
3 Suggested Answers
SOURCE: technika dishwasher model tdx6ss-2 has
Did you get this fixed? I have the same problem.
Posted on Jan 08, 2011
  • 901 Answers
SOURCE: can not change the programmes. pre rinse light is ...
Refer user manual. Check your inlet water flow.
Contact service provider for further assistance.
Posted on May 24, 2010
Why doesn't it go past the "pre-rinse" stage?
I would say that there's a very high probability that the heater in the machine has failed. It does the cold pre-rinse but when it gos to the next stage and tries to engage the water heater it detects an open circuit and faults out. You will find replacement heaters on eBay and probably videos on how to replace on YouTube
Sep 15, 2015 | Hoover Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Programming
Your dishwasher drawer appears to have got stuck in some sort of a diagnostic mode. The 3 lights are a code telling which diagnostic it is in.
I am assuming you have turned off and on at the mains power and it makes no difference.
I need to check a few things with you first, but I am assuming the controller is not looking good. The easiest way to confirm this is take the controller from the top one and try it below. But you need to feel comfortable doing it.
Let me know if you want to call a technician or do it yourself.
Jun 20, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Can not change the programmes. Pre rinse light is flashing and it just beeps when its closed. Tried all connections and have emptied it?
May 21, 2010 | Dishwashers
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Dec 06, 2009 | Hoover Dishwashers
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Nov 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
338 people viewed this question
Top Dishwashers Experts
